Clear coat over Epoxy
Postby western traveler » Wed Jun 02, 2021 2:55 pm
I am striving for a natural finish...
Here is the situation and questions. While fiberglassing my first wall yesterday, I went too heavy with my first fill coat. It will need sanding and another coat of epoxy.
I did the second wall today learning from yesterday’s mistakes.
Today’s wall has a bit of air bubbles in it but it is pretty close. I will do a light third coat.
We have a long thermometer here right now and I have tried to control the garage environment with the wood and epoxy temps but I think it is off gassing.
Can I lightly sand the panels when done and apply varnish to get the shine back? I know I need the UV protection and I want a glossy finish...
western traveler
Images: 264
Re: Clear coat over Epoxy
Postby tony.latham » Wed Jun 02, 2021 4:47 pm
Yep. No problemo.
Postby western traveler » Wed Jun 02, 2021 5:06 pm
Tony,
Thanks for the response. I didn’t want to compound the issue.
I doubt I can get the finish as smooth as I want without the last coat of epoxy being sanded out...
western traveler
Images: 264
Postby Sparksalot » Wed Jun 02, 2021 6:05 pm
Epoxy isn’t UV stable so you’re going to want several coats of good spar varnish anyway.
Sparksalot
Images: 682
Postby swoody126 » Thu Jun 03, 2021 6:08 am
YES!
that is actually the standard procedure w/ pox
once you have all your cloth weave filled enuff to sand back for a smooth surface it is then time to apply several coats of good SPAR VARNISH to protect the pox frum UV as mentioned above
sw
swoody126
