* If I'm not too late to the party, I'd like to suggest adding steel backing plates to your fenders, then leaving a small gap between them and your trailer wall. The backing plate will absorb/deflect/contain damaging road debris (or even a catastrophic blow-out at speed), and the offset from the wall will further protect the trailer. And, as I found out, keep someone that jumped on my fender from tearing it away from the wall (if it had been screwed to it). My rationale, based on some experience with old cars:
- fender mounting rationale pictured.jpg (247.83 KiB) Viewed 258 times
* I bought my 16 gauge steel fenders fom Southwest Wheel in Dallas in 2011, for less than in the picture below, but even at the new prices, they have been worth it. I originally planned to wall-mount them, using the backing plates, but since my frame extends 1" outward from the walls, I took advantage of the spacing, and welded them to the frame (with added bracing on the front and rear fender lips. Since someone jumped on one fender and slightly bent in downward (hardly noticeable), I know that his 280 lb weight would've ripped it from the wall, if attached by thru-bolts or screws. zHere's the current listing for the fenders & backing plates (I presume that the backing plates are available separately, too):
- fender & backing plate kit, from Southwest Wheel.JPG (83.57 KiB) Viewed 258 times
* Another point in favor of the added spacing: if ever you decide to get a wider axle or wider tires, you might not need to get wider fenders. I installed a wider, stronger axle a year or so after the fenders were on, and the tires still fit under the fender (though the axle was 2" wider). Another year later, I installed much wider LT tires, and made fender flares to cover the 1/4" that protruded from beneath the fenders. These fenders have been worth it ($48 ??? at the time, I think).
