Best way to fill seams, gaps and staple holes?
Postby Bretster » Fri Jul 29, 2022 7:46 pm
Hi All,
What is the best product or DIY to fill exterior seams, gaps, staple and screw holes? Will be painted so not worried about color, just need it to not fall out and be waterproof. Following are some ideas:
- PVA sawdust slurry
- Sikaflex 291 (can’t get 292 around here)
- automotive body filler
Thanks much!
Bret
Bretster
Re: Best way to fill seams, gaps and staple holes?
Postby JasenC » Fri Jul 29, 2022 8:13 pm
For screw holes, knot holes etc, Minwax high performance wood filler.
If it's a joint that is going to have some movement/flexing, Sika.
I'll be done when I'm finished, if that's not fast enough, take a number.
Build Thread https://www.tnttt.com/viewtopic.php?f=50&t=74269
JasenC
Images: 122
Postby Philip » Sat Jul 30, 2022 9:11 am
Look around in the big box stores. Around the flooring section there will be tubes of floor repair putty. You can get in colors. It doesn't shrink when it dry's. It takes paint very good. I haven't used it on screw holes. Staples, brad holes it works very well. I also used it for corner gaps. It doesn't have linseed oil in it. There is no long turn shrinkage problems.
I used it on my camper and sprinter builds. I have found any pop out from my travels on the van.
Philip
Images: 323
Postby tony.latham » Sat Jul 30, 2022 4:08 pm
or DIY to fill exterior seams, gaps...
How big are the gaps?
Postby Bretster » Sat Jul 30, 2022 5:00 pm
Biggest gap is less than 1/8”, mostly more like 1/16” or less. And a couple spots where butt ends are uneven and will require some filling and feathering to make smooth.
Bret
Bretster
Postby tony.latham » Sat Jul 30, 2022 6:07 pm
If it were me, I'd use thickened epoxy. You'll not need to worry about it coming loose as might happen with Bondo.
Postby JasenC » Sat Jul 30, 2022 6:09 pm
That all sounds like wood filler or epoxy.
JasenC
Images: 122
Postby twisted lines » Sat Jul 30, 2022 7:45 pm
Bongos a no!
Spell check and I left it :thinking:
Racking up; And Rapin foam
twisted lines
Postby swoody126 » Sat Jul 30, 2022 8:16 pm
epoxy thickened with wood flour(not saw dust)
you can create the viscosity desired quite easily
treat the wood with un-thickened epoxy first and allow it to begin curing while you mix the wood flour into the rest of the pox to make your filler
apply the thickened mix to the still green epoxy coated wood leaving it a hair proud for fairing
sw
swoody126
Postby Bretster » Sun Jul 31, 2022 10:48 am
Thanks everyone, I think I will use wood filler for most of the staples, except for the deeper ones where my crown stapler acted up, and epoxy/wood flour for gaps. Luckily I have a very good boat supply store nearby. Here is how the trailer looks at this stage.Image
Bret
Bretster
Postby JasenC » Sun Jul 31, 2022 12:56 pm
It's coming along nicely Bret.
JasenC
Images: 122
Postby dmdc411 » Mon Aug 01, 2022 10:57 am
I used Durhams rock-hard water putty. Something my grandfather showed as a kid! I've used it for various repairs over the years! And it's cheap!
Sent from my SM-G970U using Tapatalk
dmdc411
Postby tony.latham » Mon Aug 01, 2022 1:28 pm
dmdc411 wrote:I used Durhams rock-hard water putty. Something my grandfather showed as a kid! I've used it for various repairs over the years! And it's cheap!
I use that for... mouse poison. I mix it in with rolled oats. It's plaster. :thinking:
Postby Bretster » Wed Aug 03, 2022 12:59 pm
I have a follow up question I will ask in a bit.
First some history. I have filled the staple holes with wood filler and seams, gaps and screws with epoxy/wood flour. I like the wood flour, it makes the epoxy easier to work with. The epoxy is not the easiest stuff to sand and I am finding that the edges are somewhat difficult to feather into the surroundings. I don’t want to be too aggressive since this is 1/8” ply.
My first question is, can I use wood filler to feather the epoxy ridge? It means that wood filler will in some cases either butt against epoxy or will form a thin cover over the epoxy. Will this cause issues with adhesion in the future?
Thanks again everyone for your insights. I can see the end in sight at which point I plan to post some photos and some notes.
Bret
Bretster
Postby tony.latham » Wed Aug 03, 2022 2:49 pm
The epoxy is not the easiest stuff to sand and...
Are you fiberglassing over it? (Epoxy thickened with micro balloons makes for easy sandy, BTW.)
