What 1/8” ply are you referring to?Onajourney wrote:You guys crack me up with all this BB sillyness. There are a ton of exterior options especially if you are epoxing and skinning it. As for the interior, I am going with a mahogany ply walls and a BB ceiling. Use what is available to you in your budget and what you actually like.
[/quote]kokomoto wrote:
Using luan/utility/mahogany has been tried by some with sometimes disappointing results.
Wendellnla wrote:I’m in the design/planning stage and wondering if anyone has come up with decent alternatives to BB?
My build does not have to be a wood finished interior, but it would be more appropriate considering I want my build to have a cedar woodie exterior.
I have looked into FRP, but too ugly/cheap looking, but plenty flexible. Not sure how it would work structurally.
Also, thinking about a foam backed marine grade fabric or vinyl that some in an assortment of colors. Adds nothing structurally, but a small amount of insulation value….. maybe!
Regards
Wendell
I'm looking for an alternative to 1/8 in birch.
Pmullen503 wrote:Do not use this stuff!
I used just bits here and there in my foamie and it delaminated after a few years. This was on vertical surfaces covered with PMF. This was not soaking in water just subject to temperature and moisture changes throughout the year.
Ethantillema77 wrote:Ok so I'm building my first teardrop and I'm looking for an alternative to 1/8 in birch. Is Revolution ply from Lowes a good alternative. I'm using Tony's profile so I've got a pretty sharp curve
tony.latham wrote:Not sure how it would work structurally.
FRP isn't a structural member.
Users browsing this forum: No registered users and 60 guests
