How do I fix this? Cracks, visible seams in side wall, hinge
Postby grr067 » Wed Feb 01, 2023 3:53 pm
Hi! New here, so apologies if any of this is not correct process!
I bought this 'new to me' teardrop and would like to do some restoration.
I noticed some issues where the hinge meets the side wall. See photos below of each side. What's the best way to fix these cracks and the seam? Also, the hinge does not extend past the sidewall. It looks like the previous owner had covered it with tape and I'd like to do something more permanent. I'm considering extending the metal trim under the hinge and replacing the hinge with a slightly longer one, but if there's an easier way then I'm all ears.
Separately, can you tell what material the side wall is? Is it painted wood?
Thank you in advance! Really appreciate any help as I jump into the teardrop world!
grr067
Re: How do I fix this? Cracks, visible seams in side wall, h
Postby swoody126 » Wed Feb 01, 2023 7:32 pm
IMHO, what you are calling CRACKS is actually DELAMINATION of the roof panel
yes cutting the hinge too short is a major factor
i see a rear hatch removal in your future to determine the extent of the damage
in my reading here and on other "home made trailer" sites this is not uncommon
folks just butt their joints and hide them under aluminium trim to be forgotten which obviously isn't adequate
once you get the hinge n hatch removed you will be better able to evaluate your situation and then formulate your direction
any time you leave the edge of plywood unsealed this will happen over time
¿time? this depends a lot on use and storage patterns
trailers n boats suffer the same issue and glassing over plywood edges with fiberglass set in epoxy(not "fiberglass resin) has become the standard for prevention of this issue
yes this process is time consuming AND more costly than just smearing some pookey over the edges and hiding them under aluminium trim
further pics will be needed
BON CHANCE
sw
swoody126
Postby tony.latham » Wed Feb 01, 2023 8:06 pm
As swoody says, pull everything, and fix the damage and then install a proper length hinge.
You might have to get as much epoxy as possible in the delaminations.
Postby grr067 » Wed Feb 01, 2023 8:56 pm
Thank you! This is really helpful for me, so I can start googling with the right verbiage :D
When you say "pull everything," do you also mean the metal trim on the left side of the photo (opposite direction of the hinge)? [Sorry, I don't quite know all the right terms yet.]
Thank you, again!
grr067
Postby tony.latham » Wed Feb 01, 2023 9:18 pm
When you say "pull everything," do you also mean the metal trim on the left ...
Yes, pull the hatch, pull the hinge, and the trim.
Postby twisted lines » Wed Feb 01, 2023 9:20 pm
That for a foot at least.
Racking up; And Rapin foam
twisted lines
Postby grr067 » Fri Feb 03, 2023 12:24 am
Thank you! Really appreciate all the help!
grr067
Postby swoody126 » Fri Feb 03, 2023 5:04 pm
Thank you, again!
grr067, YES ... HINGE HATCH AND ALL TRIM
fix it all at this time and it will likely be a while before you have to address this issue again
since the trim wasn't installed to my standards i'm suspecting the rest of the edges will sooner than later have similar issues
sw
swoody126
Postby pchast » Fri Feb 03, 2023 9:52 pm
If you can at this time, I'd pull all the trim on the top edges and
reseal it before reinstalling the trim. Just to be certain...
pchast
Images: 97
