Looking for some comments, good idea, bad idea, etc...
I have access to enough Teak Hardwood flooring boards (for free!) to do the entire floor of my "standie" in Teak Hardwood. It will be significantly heavier then some of the other options, but I am thinking it will LOOK significantly better, and last significantly longer, and be significantly more durable...
Thoughts? Do I proceed with Teak, and work out the weight issue somewhere else on the build... or do I skip it and go with something else...
Thoughts?
**Edit**
Did some quick calculations:
5/8" ACX Sanded ply + VTC Tiles = 200lbs overall, $390
3/4" ACX Sanded Ply + VTC Tiles = 225lbs overall, $410
1/2" ACX Sanded Ply + Teak Floor = 310lbs overall, $150
Save $250 but add 75-100lbs? Worth it?
