Are we using pocket screws wrong?
Postby Tom&Shelly » Fri Dec 22, 2023 9:41 am
Just saw this:
https://www.youtube.com/watch?v=f1xnU6DE9y8
One thing Scott found is that pocket screws from the inside of a corner joint aren't as strong. Makes me wonder if we're attaching our walls to the floor correctly. Maybe we should make the holes from the outside and fill later? But I'm not aware of any broken joints to prove the point.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 1961
Re: Are we using pocket screws wrong?
Postby John61CT » Fri Dec 22, 2023 10:26 am
Key takeaway
Don't use them at all unless necessary.
Longer regular screws from the outside, with glue
is much much stronger
John61CT
Postby tony.latham » Fri Dec 22, 2023 11:18 am
Pocket screw joinery is highly effective in the right places.
Longer regular screws from the outside...
Plywood is best joined with pocket screws since screwing parallel into the laminations often causes splitting.
I use Jay Bates's pocket joinery system for building drawers:
https://youtu.be/sKVo-rLv-W8?si=euniroG6OBTI8q3R
As he puts it, "strong and quick." And since I've been doing drawers using his method for at least eight years, they last. But yeah, there's a right and a wrong way.
Postby Tom&Shelly » Fri Dec 22, 2023 12:06 pm
John61CT wrote:Key takeaway
Hi John,
That's interesting, and not quite what Scott (on the video) found. What is your experience?
Tom&Shelly
Images: 1961
Postby philpom » Wed Jan 17, 2024 9:25 pm
I recently saw this same video and instantly thought about this forum. Using them from the outside is good, from the inside, not so good. Longer screws straight threw the outside better (from a joint strength point of view), with glue way better regardless.
I used zero pocket screws on my build, everything was through from the outside, pre-drilled and countersunk. That's what my skill/tool set allowed for, no worries here. Mostly 2" and 3" screws with a few 1.5" sprinkled in.
philpom
Images: 100
Postby Squigie » Thu Jan 18, 2024 2:51 pm
Into solid wood, I wouldn't worry about it.
But I am firmly on the side of 'don't drive between laminations in plywood'. Not a good fastening.
Squigie
Users browsing this forum: WestCoastWhale and 33 guests
