JamesW wrote:It sounds like it is just a power supply. Are you planning on having a battery system in the TD? ( I recommend ) If so, there is no need for a DC power supply...
mikeschn wrote:Hey Chuck,
I put my battery in a battery box in the tongue chest, with a vent to the outside.
However, the Hawker line of batteries is completely sealed. It doesn't emit any gasses when charging or discharging. I wonder it that's the battery that the guys are talking about??? What do you know about these batteries???
http://www.batterymart.com/battery.mv?c=odyssey
mikeschn wrote:Sure... clockwise starting with the white battery box...
1) Battery box with size 24 battery
2) Battery charger
3) Sealed Hawker battery
4) 7# propane bottle
5) 110V plug with switch
6) All sitting inside a 4' wide tongue chest!
Chuck Craven wrote:Even the Huwker battery will out gas..
But if the normal deep cycle batteries are used you need an upper and lower vent, Chuck
