Went and pick up th Aluminum yesterday. It is 4x8 on the cubby need an 4x10 sheet to complete the roof. After looking some more found 4x10 sheet, but they are not (Anodize) spelling could be wrong.. What to do???
I like the look of the Anodize
1. used two sheets of the 4x8 to complete the roof
used butt joint or overlap the sheet so water does not get in. used a 1x2 in wide flat aluminum to cover the joint....
2. go with the single sheet 4x10 but is not Anodize...???>>>
If I with the single sheet could use the other sheet for the counter top...
any ideas
