xrover wrote:I built a small boat trailer out of pvc to facilitate moving my small sailboat in and out of the water. It's pretty solid stuff, and of course lightweight. I too am interested in seeing the build. Your bike looks like an engineering marvel. Remember to dry fit everything first!
TopCat wrote:Humm! PVC?
Sounds a bit on the weak side to me?
I have built a few trailers in the past months all made of WEAK materials? Wood - Angle Iron. The wheels tend to splay out when any weight is put on the trailer bed.
Regards
the pvc bike guy wrote:TopCat wrote:Humm! PVC?
Regards
If you look at my bicycles non of them are doing what you are having problems with, all of my bicycles will hold up to 1103 pounds before the frames snap and or crack. if done right PVC is stronger in many different ways then wood. I only use PVC that people are throwing away if you have not looked at my album please do. O and thanks for the input
Ivar the Red wrote:the pvc bike guy wrote:TopCat wrote:Humm! PVC?
Regards
I have a question about your bikes. I've seen some kits on line that use some sort of metal pipe inside the PVC...do you do this or is it just the PVC?
Ivar the Red wrote:This is a little bigger then I think you're looking for...but another member here built his full size tear out of PVC...
PVC TTT
Maybe an interesting read for you.
Laredo wrote:If you want it 36'' wide to haul behind a bicycle, how hard would it be to make a frame like you show in your avatar, and then cut down a piece of plywood to the proper width for a floor?
There's a set of PVC plans on the web for a lounger that shows this technique.
TopCat wrote:Not quite a teardrop but maybe along the lines you/we are thinking of?
LINK:
http://highmileagetrikes.blogspot.com/index.html#5510366049285942968
Bike Teardrop Concept.
http://www.tinyhousedesign.com/2009/05/13/ultralight-teardrop-trailer-for-a-bicycle/
Regards
Return to Bicycle Travel Trailers
