How to upload an image...
Threads about the forum, forum software, forum features, etc
Postby mikeschn » Tue Feb 14, 2012 9:35 am
How to upload an image if you don't have an album...
Click on "Gallery" in the upper right hand corner of the menu
Click on your login name behind the words "Your Personal Album"
Then click on the new image button.
Browse for the file you wish to upload...
Click on Continue
Add a description and submit.
That's all there is to it. Pretty easy once you've done it once or twice!
We modified the gallery so that it'll accept pictures up to 8 megs in size, and resize them automatically! :D
P.S. Click here for Kerry's explanation! viewtopic.php?f=26&t=49037&p=914686#p914686
Images: 479
How to put your picture into a post...
Postby mikeschn » Sun Jan 06, 2013 4:03 pm
Go to your album... and find the photo you want... click on it...
Underneath you'll see this:
Click the contents of Image-URL and then edit-copy (ctrl-c on most machines)
Go to your post
Edit-Paste (or ctrl-v on most machines)
Then highlight the url, and hit the Img Button
This is the end result with the Img tags
Submit your post and you are done!
Images: 479
How to use the album tags...
Postby mikeschn » Sun Jan 06, 2013 4:53 pm
The album tags work the same way as the Image-URL tags, except it posts a smaller picture. But when you click on the smaller picture, it expands to full size.
To post a picture with the album tags, go to your album, and click on the picture you want to post. Underneath you'll see this.
Click the contents of the album box and then edit-copy (ctrl-c on most machines)
Go to your post
It'll look like this...
Hit Submit, and you're done.
P.S. The benefit of the album method is that it doesn't use as much bandwidth... ;)
Images: 479
Help out
Postby mikeschn » Sun Jan 06, 2013 5:37 pm
If you see someone struggling with photos... or asking for help with photos, tell them to click on "Forum Problems"->"Help with Photos".
Or give them this URL... viewtopic.php?p=911290#p911290
:D
Images: 479
Return to Threads about the forum!
Users browsing this forum: No registered users and 40 guests
