Sealing my outside Walls
Threads about the forum, forum software, forum features, etc
Postby tyellow57 » Wed Oct 29, 2014 12:30 pm
Morning All
I'm need help with my outside walls, please. I have applied an epoxy sealer and like the way the wood looks. Now what do I do? I don't want to put fiber glass, but want to protect the wood. Poly, varnish or Thompsons Water Seal? Which is the best? :thinking:
Thanks for all the help, Troy
tyellow57
Re: Sealing my outside Walls
Postby tony.latham » Wed Oct 29, 2014 12:46 pm
Don't bother with the Thompson's, I think that'd be a disaster.
Epoxy is the gold standard for sealing but it is not UV resistant. You have to cover it with something to protect it from UV rays. Either a good compatible UV spar varnish (check with your epoxy manufacturer). The stuff is expensive.
Some have had success with enamel (clear) base coat used for mixing house paints. I have no personal experience with that stuff, but I think Rob here on the forum used it???
Postby tyellow57 » Wed Oct 29, 2014 3:01 pm
That is pretty much what I thought I just want to make sure. Hoping to take it out on a maiden voyage next week.
Thanks Tony
tyellow57
Return to Threads about the forum!
