I don't have a rated maximum towing capacity for my vehicle at this stage but as it is basically the same weight and dimensions as the MX-5/Miata drivetrain donor vehicle I'm going with 750kg/1653lbs which is a rating the NA series MX-5/Miata had. I'm seeking clarification with the authorities at the moment.
I've been giving more thought about putting the galley at the front and how to deal with the drawbar hindering access. I'm now thinking of making the floor slightly deeper to contain a larger section RHS extending the full trailer length which I will use to insert a removable drawbar. This means clear access to the galley will be possible but it will require front stabilisers being added. It will also provide a rear hitch for mounting a removable bike rack. I was looking at using torsion suspension half axles and strengthening of the floor/chassis side rail internally for their attachment but I will now look at going with a full-width axle cut in half with mounting plates added so I can bolt the two halves to the new larger full-length central spine to better deal with the rotational forces from the torsion suspension.
Something else I would like to consider is adding double side doors to really open it up on those nice days and they would also provide real ease of access. I would also like a skylight for bringing in the light and creating a sense of space and one that I could open would be even better.
- Double doors.jpg (86.55 KiB) Viewed 5927 times
- Double doors and skylight.jpg (62.38 KiB) Viewed 5927 times
