Along with the prize Ron sent, he also sent a drawing of his trailer design. I've reproduced it here... what do you think? Does that look like a winter design to you?
Some really simple electronics could take care of that probem, and not allow the 3rd break light turn on except when the other two lights are also on. Turn signals would be ignored, but breaking would activate the 3rd light.SteveH wrote:The problem with a third brake light, is to work properly i.e. come on with the brakes only and not with turn signals, a seperate wire is needed all the way from the stop light switch or the vehicles third brake light. That means you need a 5 pin connector, minimum.
mikeschn wrote:Along with the prize Ron sent, he also sent a drawing of his trailer design. I've reproduced it here... what do you think? Does that look like a winter design to you?
