I wouldn't think the corner on that hatch would be very strong, you making it from just wood, or metal?
John
jdarkoregon wrote:I wouldn't think the corner on that hatch would be very strong, you making it from just wood, or metal?
John
rasp wrote:cool looking adaptation.
i work for an OSB manufacturer, and with the housing as bad as it is i sure would like you to buy all the OSB you need. however, it is designed to be used for sheathing and or flooring. it does both of these jobs nicely and inexpensively. unsanded OSB is not uniform in thickness, it can vary as much as .1". for a home builder this is not a problem, for a sandwich wall on a TD it would be a problem. besides the other problem mentioned by others here, it is also heaver than plywood.
another note: plywood and OSB also can be out of square up to 1/8" measured diagonally corner to corner.
bve wrote:You appear to be missing frame materials for a tongue, and I don't see wheels and tires listed. I'm sure someone will mention using stainless screws rather than drywall screws - at least for the floor.
I'm hardly a proper consultant though, I'm still not building myself
Steve F wrote:Seems pretty cheap to me and light as well, I doubt it'll come in at either of those. What sort of coupler are you running, my offroad one was $120AUD, a road ball coupler will have very little articulation.
Steve F wrote:No battery or internal lighting? Pricing for flares and mudflaps? Is the axle price and weight including the springs, are you going to run offroad springs with a shackle and eye or just slipper springs, my axle and springs weigh a lot more than 75lbs for the lot but they are designed for offroad and the axle is solid 45mm thick steel bar.
Steve F wrote:Also, does the wood pricing include internal cabinetry as well and the bench in the back? The more I look the more questions I have Is 12ft of wiring for the taillights and hooked to the jeep, I guess with no internal lighting etc you wont need any more, I've gone through heaps in mine along with switches, battery charger, DVD/CD/Car Stereo, LCD screen, LED lighting etc.
Anyway, it should be a fun build to watch.
Cheers
mikeschn wrote:That's some nice cad work on your design.
How high is the gallery from the ground?
I've also got some more cad projects if you are interested.
mikeschn wrote:I've also got some more cad projects if you are interested.
stomperxj wrote:Thanks for the nice comments Mike... I have been using Autocad since about 1989 or so. Started with release 10
Mary K wrote:
Careful, he now knows you can do 3D.
Mk
