Its just a little fun because it has been said here that these little trailers are not supposed to be "RVs" Meaning flush toilets and showers do not belong. Since my concept is a ridiculously small trailer with a toilet and shower it seem appropriate.Oldragbaggers wrote:What does the "not a RV" refer to? I must be missing something.
Becky
My tow vehicle is a mini van so I have the hatch back type door. I would think if you were doing a tail gate on your TV that your idea of surrounding the tail gate is the best. On my mini van there is a large rubber seal and I was thinking one could make a thin plywood shape that would follow the seal shape (like a donut) and sew that into the fabric tunnel. You could then manufacture some way to pull the form against the rubber seal and make a perfect connection. Probably bunge cord.donrebyct wrote:I really like this, but I'm wondering if the tailgate should be covered by the tunnel canvas. My first thought was to slip the cover over the tailgate & secure with bungi cords. This would protect the inside of the tailgate while open at camp.
Setup would be a bit of a hassle, but this is a fascinating and inexpensive concept.
I think that is a very intriguing idea. I was thinking before of something a little bit similar for a pick up truck camper. In my scenario the what would slide out would actually pivot so the wall of the slide out would end up as the floor on the ground. I am sure this makes no sense in words. Bottom line what would be horizontal in the truck bed would end up being verticle one deployed.donrebyct wrote:I've been thinking about building a foam/canvas slideout mounted in the van or SUV during camping season. At site, a flap or door on the camper would open and the slideout pulled out & attached to the camper. A folded up mattress could stay in the slideout all the time. Maybe simple castors could be mounted on the slideout to roll out of the TV.
Any thoughts?
StandUpGuy wrote:I was thinking before of something a little bit similar for a pick up truck camper. In my scenario the what would slide out would actually pivot so the wall of the slide out would end up as the floor on the ground. I am sure this makes no sense in words. Bottom line what would be horizontal in the truck bed would end up being verticle one deployed.
You should draw up your idea and post it here. I like your outside of the box thinking.
Treeview wrote:StandUpGuy wrote:I was thinking before of something a little bit similar for a pick up truck camper. In my scenario the what would slide out would actually pivot so the wall of the slide out would end up as the floor on the ground. I am sure this makes no sense in words. Bottom line what would be horizontal in the truck bed would end up being verticle one deployed.
Take a look at this:
http://www.kamparoo.com/
There are other motorcycle trailers that are the same.
