CaraWhale
Postby mezmo » Thu Dec 22, 2011 12:48 am
Hi Perttu,
Merry Christmas to you and yours!
Just looking at your latest pic, it struck me - that it also looks
somewhat like a pelican with an open beak. Do they have
pelicans that far north?, Or are they just a warm climate bird, I wonder?
Either whale or pelican, why not make a fish [or two] cutout and have
it [them] overlap the side under the window area, like they are it's catch
caught in the whale's/pelican's mouth? [It/they could maybe be good luck
charms for when you go fishing in it.]
The uniqueness of you design is all the reason you need to build it.
It'll either make everyone who sees it smile, or at least make them think
a bit while they try to decide to what it is - and how often are most
people required to think anymore, these days of spoon-fed entertainment?
Just by their looking at it, you've affected them in positive manner. Ha!
Best of luck in the new year and continues success with the build.
Norm/mezmo
mezmo
Images: 194
Postby Perttu » Sat Jan 07, 2012 2:11 pm
I like camping and trekking -even my van is not ready ..
And I am huge fan of Lars Monsen fils ( Norwegen Explorer ) and you know that I am a bit stubid...
http://youtu.be/sDX7HKYQbO4
Perttu
Perttu
Postby Juneaudave » Sat Jan 07, 2012 2:37 pm
Nice video Perttu...not to different looking from SE Alaska.
:thumbsup: :thumbsup:
Juneaudave
Images: 380
Postby Perttu » Wed Jan 11, 2012 2:17 pm
I made the floor from 6mm film plywood ( anti slip surface )
Perttu
Perttu
Postby droid_ca » Wed Jan 11, 2012 2:47 pm
I love the concept to this trailer/boat it'll be intresting to see both on land and water :thumbsup: :thumbsup: :thumbsup: :thumbsup:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby TJinPgh » Thu Jan 12, 2012 8:40 pm
Perttu,
Love the concept. Can't wait to see the finished product.
Kind of curous. In your initial drawing you showed it with an outboard engine while it's in the water.
Was wondering if that is the plan? If so, where do you store the motor when it's not in use? And I'm not quite seeing how it would mount to the back. Even with the steps removed there is the rear portion of the trailer frame that I would think would prevent you from mounting it up top?
-TJ
TJinPgh
Images: 90
Postby Perttu » Fri Jan 13, 2012 11:19 am
Hi
Here is how I am going to make the back :
There will be 3 removable grills on back ( 15mm film ply )
They vill be fastened with bolts to transom.
Outboard can be transport when one side grill is removed - still clear way to cabin. And ladder should have enough room to tilt.
And on water the center grill will be removed and outboard is placed to middle.
Perttu
Perttu
Postby TJinPgh » Fri Jan 13, 2012 1:11 pm
Ahh. Ok.
I think what was throwing me off was the part of the frame where the ladder sits. I kept forgetting that the boat would be removed from the frame of the trailer while in the water.
How difficult do you forsee disconnecting and reconnecting the boat to the trailer will be?
-TJ
TJinPgh
Images: 90
Postby Perttu » Sat Jan 14, 2012 4:20 am
How difficult do you forsee disconnecting and reconnecting the boat to the trailer will be?[/quote]
The boat is connected with " truck style lines...."..
I will make the back ligths and ladders removable and just drove the trailer enoug to water - so the boat bottom meets the water. That wounld not so too good for wheel bearings, but they can be renewed if needed...
Perttu
Perttu
Postby TJinPgh » Sat Jan 14, 2012 9:57 am
could probably find some waterproof hubs or whatever it is that they use on boat trailers.
-TJ
TJinPgh
Images: 90
Postby Perttu » Sun Jan 22, 2012 1:56 pm
glued roof today
Inside is lot roomy than I thought. Full sitting room even on front table
Perttu
Perttu
Postby droid_ca » Sun Jan 22, 2012 2:06 pm
wow your vision is becoming a reality Good Job :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
“Fide Canem”
droid_ca
Images: 176
Postby IndyTom » Sun Jan 22, 2012 2:36 pm
WOW! This is one of the coolest builds I have seen in a long time. I love the little campers and I love boats, to this is the best of both worlds.
Can't wait to see it finished.
Never trust a skinny cook
IndyTom
Images: 42
Postby Perttu » Sat Jan 28, 2012 12:49 pm
Hi and thanks for comments.
Boats have names - I am not sure should trailer/boat has name too.
So I may do small name stickers
I thougth that carawhale is good name or kaskelotti ( spherm whale in finnish language ).
But I may go with whales tear - It saunds nice. But should I write it:
1. whales tear
2. whale´s tear
3 tear of the whale
4 or some another way
I am poor whit grammars even my own language?
Perttu
Perttu
Postby Perttu » Mon Jan 30, 2012 12:01 pm
Bit too could to heat up carage for gluing and painting -
time to play with computer...
Perttu
Perttu
Return to Member Designs
