capnTelescope wrote:Strength and light weight are the main goals. I haven't seen even one builder complain that their Tear wasn't heavy enough. I also want to minimize the amount of left-over dead tree.
Most designs have a number of subcomponents that are added after some initial assembly. Most notably, bulkheads, the cabinetry in the cabin and galley. My design makes these an integral part of the structure, adding strength while adding minimal extra weight.
capnTelescope wrote:Also, we often make some compromises with good woodworking practices. Most notable here is the common way of installing bulkheads and roof spars. Often, bulkheads are mounted by screws from the outside into the edges of the bulkhead plywood. This has several disadvantages. Most notably, screwing into end grain risks splitting the wood. It is less stronger than a screw through the face of the plywood. But IMHO the bulkheads can be one of the main sources of strength of the basic cabin assembly of floor, walls and bulkheads. Also, the through screws from the outside make extra work, as you usually see them countersunk and filled over and sanded. That's a lot of extra work. It also prevents you from skinning and trimming the walls until after assembly. When the walls are vertical, you have to fight gravity. So I want to skin the wall subassemblies on the workbench, before any assembly begins. I'm risking scratches and dings, so we'll see how that goes.
capnTelescope wrote:Video is up!
Includes a tour of the machine and the actual drawing on the plywood. I also left in a couple of "oops-es" for comic relief. I had a couple of problems related to my not usually going to the extremes on the axes.
It ain't purty, but it's real.
capnTelescope wrote:Hi Tom, welcome to my humble thread and a hearty Class of '72 Howdy to you. I thought it was time for another Aggie to speak up.
I've been following your posts and Silver Beetle build for some time. You did a great job on your Tear!
capnTelescope wrote:I plan to skin my tear with sheet aluminum, probably .030 thick or less if I can find it in 4x10. I want a shiny one like you have.
capnTelescope wrote:The Dreaded Hatch
I'm glad you asked that question. I'm planning to merrily head off into the tall grass, here (kinda like how I play golf).
While I look into Len's method, I'll leave everyone with a question to ponder:
What common household item closely resembles a teardrop hatch?
Answer tomorrow, PLUS how I plan to build my hatch. I haven't seen anything like it on this forum.
