Steve, Number One weighed in at 600kg and I had 750kg rated springs on it. Worked an absolute treat. Number Two weighs in at 450kg with 650kg rated springs and that works a treat as well.
Cheers
Paul
PaulC wrote:Steve, Number One weighed in at 600kg and I had 750kg rated springs on it. Worked an absolute treat. Number Two weighs in at 450kg with 650kg rated springs and that works a treat as well.
Cheers
Paul
nightranger_02 wrote:That would be great for my Ranger . I got a lifted Ford Ranger
highlandercj-7 wrote:Steve have you thought about using a Jeep fuel tank for your trailer. CJ's us a nice steel 15 gal tank that is small and compact. Mount it under your trailer You can then use a electric fuel pump to transfer the fuel to your Jeep. Perhaps make a swing away spare tire holder like your XJ to mount your Trailer spare.
Here's a link to the tank:
http://www.4wd.com/productdetails.aspx?jeep-sid=2&plID=0&partID=11067
Wright wrote:Say, just a thought here, using that jeep fuel cell as water tank. after a couple of Mod's and maybe coating the inside with like an enamel coating... just thinking out loud....
