Wiring done, no finders at this time. this is a 2 part trailer. lower part will be taken in, in Feb for plates. by then I should have pixs.
Upper body floor, side walls, and rear hatch support done. assembly will Start as soon as I get the floor turned around. it is facing the wrong way in the garage.
After I get that done then I will work on getting it on the trailer. Andrew has helped figure much of that out.
Galley will be built last and I will be alful hungry by then.
Ron D.
