Offroad trailer w/ inside seating
Postby StormRider » Tue Nov 03, 2009 7:18 pm
Finally figured out sketchup enough to work on an offroad trailer design w/ inside seating. This is for quick 2-4 day trips into the more remote areas of Utah.
Tires are 35" x 12.5" - same as my jeep.
bed is 60" x 80", and built over the top of the wheel wells.
body is 5' x 8'
the foot of the bed can be lifted up for access to a foot well, allowing comfortable seating. Add a drop down table and some kind of seatback, and it should be a comfortable place to avoid poor/cold weather.
these initial sketches are mostly about validating that the footwell doesn't hang down too low, and if the overall height is reasonable (80")
<img src="http://hphotos-snc3.fbcdn.net/hs358.snc3/29513_1365097661413_1650789676_863167_8282475_n.jpg"/>
Build Journal
StormRider
Postby Endo » Tue Nov 03, 2009 7:49 pm
I like the profile of your design.
Do you have a view of the exterior showing the door?
Are you going to have a galley?
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby StormRider » Wed Nov 04, 2009 1:08 am
I've not done the doors yet- i'm looking to see if it's easier/faster to buy doors instead of making them.
I'm planning on a simple galley in the back- because of the trailer height the main work surface will be on the trailer deck.
Build Journal
StormRider
Door source?
Postby StormRider » Wed Nov 04, 2009 12:54 pm
Anyone know where to source doors like the ones these trailers?
http://www.tnttt.com/viewtopic.php?t=24336
Build Journal
StormRider
Postby Endo » Wed Nov 04, 2009 3:50 pm
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Return to Member Designs
