There is another build in progress that is using an air bag suspension;
http://www.tnttt.com/viewtopic.php?t=33063
unforgiven wrote:it actually has me thinking. the plan was to get the same ground clearance as the jeep. the only way to actually achieve more ground clearance is with larger tire size. butttt, with your post, i got to thinkin on that. now with the jeep, you have the bottom of the diff as your lowest point. but with the trailer, it's only a straight axle, so using the same size tires you actually achieve about 4 inches ?? more clearance.
unforgiven wrote:so, oldtamiyaphile, are you on rcjeeps as well? just curious, as it seems to be the most sought after rc for crawling.
Endo wrote:I really like the shape!
Could you eliminate the front hatch and make a hinged or removable lower wall in the galley to insert the mattress?
Is the floor of the teardrop going to serve as the "counter top" of the galley due to the overall height of the teardrop?
unforgiven wrote:
darryl
