Hello All,
I have finally started to waste memory space at work to design my Teardrop. I thought I would share as I go along. Tips and Constructive Critisism is welcome from all. I have been lurking for a few months and have learned allot from everyone.
These shots are of my current design, and as you see they are far from complete. So, I have allot of it designed in my head and I have not had time to model it up yet, and some of it is just open still. My goal is to have the 3-D model complete some time in mid-Aug. and to start the frame at that time. And then the body will be a slow process as I have time over the winter.
Some of the design constraints and unique features are as follows:
Tow vehicle - 2002 Honda CR-V
Intended to be towed across country. Aka 3000 mile trips.
Emprty weight - less than 1000#. NYS requirement for brakes is greater than 1000#
Wheels will be matching to the CR-V. One spare for the entire setup.
Bolt Circle for the CR-V 5x115mm or 5x4.527 If the wheels don't fit the standard 5x4.5 I will move the bolt pattern to fit.
Must be able to open rear door of CR-V.
Basic dimensions 5'x8'. More comfort with the 5'W and 8'L is to minimize the overall weight and size.
Torsion Axle (looking at Dexter #9 right now.)
Lightweight/Midweight 2x2x11ga.(.120") frame. 3/4" plywood floor bolted on.
Long storage under the floor for paddles etc.
Side wall construction of 1/2 plywood.
Roof Construction 5x5 sheets of 1/4" Baltic Birch. Unknown covering over that.
Plans for a insulated compartment for the Ice Chest to extend ice times.
Full Matress 54x75. I am 6' even so I don't want to have to remove my feet to sleep comfortablely.
That is all I can think of at this time. I will keep you posted as I dream up more stuff at work.
Here are a few shots. The first was my planned profile, but as I quickly learned keeping an 8' length isn't allot of room for the cooler area. So in true Mechanical Engineering style Function takes priority over Fashion. The new side profile is more basic, but still has a decent shape.
