CaraWhale
Postby StandUpGuy » Wed Nov 16, 2011 8:11 am
Have you used a marine grade plywood on the hull or at least an exterior grade?
StandUpGuy
Images: 52
Postby Perttu » Thu Nov 17, 2011 12:53 am
Hi
Here in Finland all plywood are made with same waterproof glue. Only guality of vaneers changes. So I use "standart" quality ply - its qood enough and cheaper.
I have made some boats and canoes and they have lasted ok :
Stevenson Weekender
http://youtu.be/j74abpeZu2M
Michael Storer´s OzRacer :
http://youtu.be/IiZ_hkEN5rg
Then I made cabin sailboat to same platform ( this design I made plans with Micahael Storer )
and video :
http://youtu.be/YhlAfUweOcw
And bigger version of same platform :
( not build yet )
Selway Fishrer Esk kayak :
http://youtu.be/xqluCoWqixo
Michael Storer´s Quick canoe :
http://youtu.be/IJgWXsZC7Bg
Two own design "play" kayaks , here the better one:
( I made V bottom from one sheet )
and more photos :
http://s1121.photobucket.com/albums/l51 ... a%20shark/
Here is my first drawing of van:
[img]<a%20href="http://www.flickr.com/photos/34155447@N02/5216814435/"%20title="v1%20by%20penapepe,%20on%20Flickr"><img%20src="http://farm5.static.flickr.com/4088/5216814435_aace51ea09.jpg"%20width="330"%20height="500"%20alt="v1"></a>[/img][/url]
[img]<a%20href="http://www.flickr.com/photos/34155447@N02/5217402766/"%20title="v2%20by%20penapepe,%20on%20Flickr"><img%20src="http://farm6.static.flickr.com/5244/5217402766_ee5ba67184.jpg"%20width="500"%20height="353"%20alt="v2"></a>[/img][url][/url]
Perttu
Perttu
Postby StandUpGuy » Thu Nov 17, 2011 8:32 am
Perttu wrote:Hi
Here in Finland all plywood are made with same waterproof glue. Only guality of vaneers changes. So I use "standart" quality ply - its qood enough and cheaper. ....
Perttu
Good so if the ply is a waterproof glue type and you glass the seams then you are good. You know what you are doing.
The little cabin cruiser sailboat you built is pretty cool. Obviously it does not plane the water very cleanly but it is a lot of boat for a short length. I am thinking of building next year a 4 meter long sailboat that the hull breaks down to two halves. This way I can put the boat inside my van and still pull my trailer.
StandUpGuy
Images: 52
Postby StandUpGuy » Sat Nov 19, 2011 10:59 am
So your "Ocean Cruiser" is built on a PD Racer hull? Amazing.
StandUpGuy
Images: 52
Postby Perttu » Mon Nov 21, 2011 12:17 am
Hi
Yep it´s "modifed pdracer" -rocker curve and bow angle are not sama as pdracer.
Yesterday I glued bottom to my van - I had camera with me but did not remenber to take photo - today I glue bottom runners.
Perttu
Perttu
Postby StandUpGuy » Mon Nov 21, 2011 7:33 am
Perttu wrote:Hi
Perttu
I will be interested in seeing your larger version of the Ocean Explorer built. Pretty amazing how much function and space you got out of the small one. Bravo!
StandUpGuy
Images: 52
Postby Perttu » Mon Nov 21, 2011 2:15 pm
Glued bottom runners - next some putty and sanding....
On spring there should be atleast two of the bigger boats ready to maiden voyage - lets see how it comes.
here is more info of that boat if intrestes - also rotatable 3d model.
http://www.duckworksbbs.com/plans/korho ... /index.htm
here is "funny " story of one trip that I made with that smaller one :
http://www.duckworksmagazine.com/10/out ... /index.htm
Perttu
Postby Perttu » Tue Dec 06, 2011 7:39 am
Hi
Some sanding and glass taping and finally paint first coat of primer
Actually now I got Flinstones type of van....
Perttu
Perttu
Postby StandUpGuy » Wed Dec 07, 2011 3:57 pm
Looking good. Keep it going as long as you can stand the cold and snow!
Is it a Flintstone's van because turned over your feet poke out the bottom? Did you portage your trailer like a canoe to get it outside to dry? 8)
StandUpGuy
Images: 52
Postby Perttu » Thu Dec 08, 2011 12:18 am
Hi
I sand outside - the carage is warm so no worry...
Perttu
Perttu
Postby Perttu » Wed Dec 14, 2011 1:35 pm
I think I will make removable ladders to trailer frame. When the whale is going to water I remove the ladders and trailer lights and drove the whole trailer to water.
in picture is just the idea - its not the final solution.
Perttu
Perttu
Postby StandUpGuy » Wed Dec 14, 2011 8:05 pm
I think it is a great idea. It make the boat trailer more of a trailer trailer when on land. I cannot wait to see photos of you next spring with your smiling face looking out of the whale's mouth on the water. :beer:
StandUpGuy
Images: 52
Postby Perttu » Sat Dec 17, 2011 1:54 pm
I think I will make the ladders like this :
Finally got the bottom painted. Two coats of polyester paint two layers of alkyde primer and three coats of alkyd paint.
Next I will fasten bottom runners ( aluminium ) - turn it over and start waiting the santa!
Perttu
Perttu
Postby S. Heisley » Sat Dec 17, 2011 9:39 pm
This is going to be so-o-o-o cute!!!!
I'm enjoying watching this one! :thumbsup: :applause:
Postby Perttu » Wed Dec 21, 2011 2:21 pm
Sometimes I feel a bit stubid while doing this project - sometimes it feels funny and sometimes it feels even a bit reasonable - now I feel a bit stubid.... but anyhow it´s been fun so far.
Merry Christmas to every one!
Perttu
Perttu
Return to Member Designs
