I find it fun when I see others have had my idea
Postby Ron Dickey » Fri Aug 19, 2005 10:20 pm
I find it always interesting that when I think I have come up with an origanal idea some one else did it first. but then alot of my idea for the Box Kite was barrowed from many many pictures I have seen.
http://www.rallymastercampingpods.com/pages/3/
121377......134179
Ron Dickey
Images: 711
Postby Ron Dickey » Fri Aug 19, 2005 11:13 pm
I am planing to have side doors. I was planning on making it flat at the rear but if it went up in the rear like this one I could almost stand at the rear to change clothing and such. the idea of using the lower ramp as a base to keep the upper lid up looks worth while.
I had wanted to put it in a trailer like this then I realized when I was talking to Peter from Mac Bult teardrop trailers that I could have as many trailers as I wanted. The have no engine and there for plate tags and insurence would be little to nothing. I could even get rid of my truck if I had use of a unit strong enough to pull a trailer holding heavy things I would put in the rear of the truck. Unless I get a 5th wheel, or make one. like the skamp.
Andrew showed one being pulled by a mini car with a window at the front slant.
I am also thinking of a pull out rear floor rather then a drop down rear floor.
like you see now in utility vans like this
http://cargobody.com/rolling_cargo_deck.htm
it could drop into place. The galley could sit on the end and be pull out.
121377......134179
Ron Dickey
Images: 711
Ideas
Postby PaulC » Sat Aug 20, 2005 4:51 am
Ron, check this sitehttp://www.active4x4.com/Black%20Widow/black_widow.htm for unique custom made storage :D
PaulC
PaulC
3rd Teardrop Club
Images: 36
Re: I find it fun when I see others have had my idea
Postby Flonker » Wed Nov 02, 2005 6:46 pm
Ron Dickey wrote:I find it always interesting that when I think I have come up with an origanal idea some one else did it first. but then alot of my idea for the Box Kite was barrowed from many many pictures I have seen.
Takes me right to a page that wants everything up to DNA sample & such. I hate when that happens.
Flonker
Return to Member Designs
