Northern Lite Traveler
Re: Northern Lite Traveler
Postby mezmo » Mon Feb 01, 2016 11:10 pm
'Very generous of you to take the time and share all those building drawings !
mezmo
Images: 194
Postby Texican » Fri May 13, 2016 12:05 pm
I love this shape and design, thanks for sharing your drawings.
Texican
Postby SMCbivy9007 » Tue Sep 12, 2017 9:22 pm
Beautiful build. Exceptionally clean and finished. :thumbsup:
SMCbivy9007
Images: 44
Postby J.Pierson » Fri Oct 13, 2017 7:54 am
I don't know how I had missed this build before. It is incredible! Thank you for sharing and documenting so well!
Sent from my LG-AS330 using Tapatalk
J.Pierson
Postby OP827 » Wed Nov 29, 2017 7:40 pm
Thanks for sharing your experience here, very nice builds! :thumbsup:
OP827
Images: 405
Postby Ottsville » Fri May 18, 2018 6:39 am
What a beautiful build and thank you for sharing your designs and trailer ideas!
Ottsville
Postby PatrickM » Fri May 25, 2018 3:29 pm
Hi - I have order ordered my aluminum to copy this technique -- U say 3/16 rivets, I am assuming width based on the material you are going through 3/16 is not long enough - so what length did you use - I am rivet ignorant so need all the all the help I can get. :?
Possibly a link to source :D
Cheers, Patrick
Be kind and respectful to everyone - but dont take sh!t from nobody!
PatrickM
Images: 6
Postby alaska teardrop » Sun May 27, 2018 1:30 pm
Thank you all for the compliments. Well, it's been awhile. Time for an update.
The Northern Lite has traveled several thousand miles, including a seven week trip of western states, the Pacific coast and the last Redwood Gathering. No issues except a flat tire and no changes made to the trailer. I have added a tongue box and a 30 amp AGM battery with AC charger.
:peace: Fred
Last edited by alaska teardrop on Sun May 27, 2018 2:11 pm, edited 1 time in total.
alaska teardrop
Postby alaska teardrop » Sun May 27, 2018 2:02 pm
Patrick, here is a link to an online rivet manufacturer.
https://hansonrivet.wpengine.com/rivets ... nd-rivets/
The PASD603H through PASD610H rivets are 3/16" diameter closed end structural aluminum rivets with a steel mandrel.
The length is determined by the grip range (i.e. the thickness of the materials that you are riveting together).
The grip range and the drill size are extremely important for a strong bond.
You could order on line, but you could probably find them at at your local industrial hardware supply.
Good luck with your build. Fred
alaska teardrop
Postby PatrickM » Sat Jun 02, 2018 3:25 pm
Thanks - picked up some rivets. Got some structurals for the internal framing work and some closed end for the outside alu sheeting work - both in the grip ranges needed. Did not know there were that many types of rivets out there
Cheers :beer:
PatrickM
Images: 6
Postby PatrickM » Tue Jun 05, 2018 8:18 pm
Hi Again
Which part# of VHB tape -- sooooo many out there
Cheers
PatrickM
Images: 6
Postby alaska teardrop » Wed Jun 06, 2018 1:54 pm
PatrickM wrote:Hi Again
Cheers
3M 4919F
https://www.3m.com/3M/en_US/company-us/ ... 236&rt=rud
Clean the surfaces with isopropyl alcohol. :thumbsup:
alaska teardrop
Postby CoffeeDude » Fri Sep 18, 2020 1:00 pm
Excellent work on your aluminum foamie lightweight trailer!
I have been reading thru your posts, to learn how to build my first TD, what is the process for your exterior trim?
Did you buy them or custom build your trim.
Thanks!
CD
CoffeeDude
Postby alaska teardrop » Mon Sep 21, 2020 5:02 pm
CoffeeDude,
Welcome aboard & thank you for the complement.
All of the trim & seals came from Trim-Lok. https://www.trimlok.com/
Grainger & other sources sell Trim-Lok products also, in smaller quantities.
Good luck with your project. :thumbsup:
alaska teardrop
Postby joshuag » Tue Dec 22, 2020 10:11 pm
Such a good build! I came back to it after 2 years and I'm still seeing things I didn't notice before... and then you provided updates on how it all worked out. Thanks again!
-Joshua
I want to build a Tipoon clone foamie but I bought a truck, so I'm not sure what I'm going to do next.
Tipoon Youtube
joshuag
Return to Member Designs
