Northern Lite Traveler
Re: Northern Lite Traveler
Postby alaska teardrop » Thu Mar 07, 2013 10:30 am
    Hi Dan,
    Glad to meet you. :shake hands:
    Looks like you're doing a mighty fine job of building a trailer yourself!
    More beer :beer:
    :peace: Fred
alaska teardrop
Postby AlgoDan » Thu Mar 07, 2013 12:05 pm
:shake hands: Hi Fred, Thanks for the compliment. Without this forum and great builds people have done here, I don't think I would have done a build....
Cheers
Dan
:beer:
alaska teardrop wrote:
    Hi Dan,
    More beer :beer:
    :peace: Fred
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby Prem » Thu Mar 07, 2013 12:35 pm
:beer:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby amblt » Fri Apr 19, 2013 2:26 pm
This is amazing. Do you expect any trouble with galvanic action between the aluminum structure and the steel frame? I only browsed through quickly- I may have missed something.
Thanks
amblt
Postby alaska teardrop » Sat Apr 20, 2013 10:02 am
amblt wrote:This is amazing. Do you expect any trouble with galvanic action between the aluminum structure and the steel frame? I only browsed through quickly- I may have missed something.
Thanks
    Thanks. Good question. No, I don't expect galvanic corrosion in this trailer to be an issue at all. Strength & durability are two of the reasons to build this way.
    Steel has a value of .85v. The aluminum used in this trailer has a value of either .90v or .95v for a total difference of .10v. That's below the acceptable difference of .15v for outdoor use.
    To prevent moisture intrusion the steel tubes for the cabin floor are welded closed. The entire steel chassis is sand blasted, acid dipped & powder coated. The VHB tape not only acts as an adhesive & seal but separates the aluminum from the powder coated steel. The only direct contact between the metals are the rivets.
    The rivets are 3/16" closed end aluminum structural rivets. Closed end rivets won't leak through the center. They make an exceptionally strong seal to close off the rivet hole. 840# tensile strength. About the same as a #10 plated machine screw & more than a stainless steel screw.
    In addition, the interior cabin has a complete vapor barrier to prevent interior moisture from entering the wall, ceiling & floor.
    Hope that answers your question.
    So, my turn. Who, what & where are you? Are you building or looking to buy? The Northern Lite Traveler is for sale BTW. viewtopic.php?f=18&t=52370
    :peace: Fred
alaska teardrop
Postby aggie79 » Sun May 05, 2013 3:24 pm
Fred,
Every time I look at this build, I'm amazed. I've tried to soak in the details of your design, and have an okay grasp of what material or technique you used. The one thing that I haven't figured out is the "trim" where the roof and sidewall meet. From your description of the interior ceiling, I'm thinking the exterior "trim" may be a "U" shaped trim applied over the sidewall aluminum before riveting with the aluminum roof skin overlapping this. Could you tell please if I'm anywhere near correct?
Thank you,
For more on our Silver Beatle teardrop:
Images: 676
Postby alaska teardrop » Mon May 06, 2013 8:11 am
    Thanks Tom,
Last edited by alaska teardrop on Thu Sep 25, 2014 10:56 am, edited 1 time in total.
alaska teardrop
Postby aggie79 » Mon May 06, 2013 1:44 pm
Thank you Fred! :thumbsup: :applause: :thumbsup:
That trim looks like it will solve a lot of issues. I need to visit the TrimLok site.
Take care,
Images: 676
Postby The Longs » Thu Aug 21, 2014 8:31 pm
Hey Fred,
I apologize if this has already been covered but what type of rivets are you using to fasten the sheet to the frame? Im in the process of building an all steel tear and love the way the rivets look.
Thanks!
The Longs
Postby alaska teardrop » Fri Aug 22, 2014 9:08 am
Hi The Longs,
I use 3/16" Aluminum Dome Head Closed End Structural rivets with Steel Mandrel. The length depends on the material thickness. I use them because they don't leak through the center, high tensile strength and the mandrel nail always breaks off out of sight, leaving the bulb in place to help maintain the tensile strength. Recommend using a pneumatic riveter.
A source would be your local industrial supplier such as Fastenal.
Example link to rivets: http://www.hansonrivet.com/closed-end-blind-rivets.htm
Fred
alaska teardrop
Postby dogscats » Fri Aug 22, 2014 11:45 am
Do you add anything to the side rivets very nice trailers
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby alaska teardrop » Fri Aug 22, 2014 4:47 pm
dogscats wrote:Do you add anything to the side rivets very nice trailers
Thank you, Dogscats.
Not sure that I understand your question. The rivets for the side, top, floor, cleats, galley & shelf mounting, fender attachment and tailgate structural angles are all Closed End Structural rivets of the appropriate length. No washers. No surfacing of the dome head like on the Airstream replacement rivets.
The interior ceiling & side panels are riveted with Large Dome Head aluminum rivets with aluminum mandrel.
Fred
alaska teardrop
Postby dogscats » Fri Aug 29, 2014 10:52 pm
Do you put any thing on top of the rivets that you on the sides any goop to help seal ? Like your frame . Did i miss what ga steel you use? Some time seam like I read to much and forget
dogscats
Images: 20
Postby alaska teardrop » Sat Aug 30, 2014 8:28 am
dogscats wrote:Do you put any thing on top of the rivets that you on the sides any goop to help seal ? Like your frame . Did i miss what ga steel you use? Some time seam like I read to much and forget
No goop necessary. The high tinsel strength of the rivet makes for a tight seal & closed end rivets don't leak through the center like a standard rivet.
This thread gives an explanation of steel sizes for the chassis: viewtopic.php?f=35&t=12220
alaska teardrop
Postby AZ_Desert_Rat » Tue Sep 09, 2014 10:08 pm
Holy smoke Fred,
A great build and some new innovative, trailer building ideas and techniques! :applause: :applause: :applause:
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Return to Member Designs
