Page 5 of 5
Re: Northern Lite Traveler
PostPosted: Mon Feb 01, 2016 11:10 pm
by mezmo
'Very generous of you to take the time and share all those building drawings !
PostPosted: Fri May 13, 2016 12:05 pm
by Texican
I love this shape and design, thanks for sharing your drawings.
PostPosted: Tue Sep 12, 2017 9:22 pm
by SMCbivy9007
Beautiful build. Exceptionally clean and finished. :thumbsup:
PostPosted: Fri Oct 13, 2017 7:54 am
by J.Pierson
I don't know how I had missed this build before. It is incredible! Thank you for sharing and documenting so well!
Sent from my LG-AS330 using Tapatalk
PostPosted: Wed Nov 29, 2017 7:40 pm
by OP827
Thanks for sharing your experience here, very nice builds! :thumbsup:
PostPosted: Fri May 18, 2018 6:39 am
by Ottsville
What a beautiful build and thank you for sharing your designs and trailer ideas!
PostPosted: Fri May 25, 2018 3:29 pm
by PatrickM
Hi - I have order ordered my aluminum to copy this technique -- U say 3/16 rivets, I am assuming width based on the material you are going through 3/16 is not long enough - so what length did you use - I am rivet ignorant so need all the all the help I can get. :?
Possibly a link to source :D
Cheers, Patrick
PostPosted: Sun May 27, 2018 1:30 pm
by alaska teardrop
Thank you all for the compliments. Well, it's been awhile. Time for an update.
The Northern Lite has traveled several thousand miles, including a seven week trip of western states, the Pacific coast and the last Redwood Gathering. No issues except a flat tire and no changes made to the trailer. I have added a tongue box and a 30 amp AGM battery with AC charger.
:peace: Fred
PostPosted: Sun May 27, 2018 2:02 pm
by alaska teardrop
Patrick, here is a link to an online rivet manufacturer.
https://hansonrivet.wpengine.com/rivets ... nd-rivets/
The PASD603H through PASD610H rivets are 3/16" diameter closed end structural aluminum rivets with a steel mandrel.
The length is determined by the grip range (i.e. the thickness of the materials that you are riveting together).
The grip range and the drill size are extremely important for a strong bond.
You could order on line, but you could probably find them at at your local industrial hardware supply.
Good luck with your build. Fred
PostPosted: Sat Jun 02, 2018 3:25 pm
by PatrickM
Thanks - picked up some rivets. Got some structurals for the internal framing work and some closed end for the outside alu sheeting work - both in the grip ranges needed. Did not know there were that many types of rivets out there
Cheers :beer:
PostPosted: Tue Jun 05, 2018 8:18 pm
by PatrickM
Hi Again
Which part# of VHB tape -- sooooo many out there
Cheers
PostPosted: Wed Jun 06, 2018 1:54 pm
by alaska teardrop
PatrickM wrote:Hi Again
Cheers
3M 4919F
https://www.3m.com/3M/en_US/company-us/ ... 236&rt=rud
Clean the surfaces with isopropyl alcohol. :thumbsup:
