TomS wrote:Thanks for the complements folks! Keep plugging away at it and you'll get yours built too,
WoodSmith wrote:Tom, not that it will do you any good on this project (looks great BTW) but an easy way to trace a line 1/4 inch bigger/smaller is to use a flat washer. Find one that has the offset that you need and put the outside against the thing your gonna trace, put the pencil inside the washer and push it against the tracing. Run it around the pattern and there you go.
Lee Valley even sells a kit with differnt size offsets. http://www.leevalley.com/wood/page.aspx?c=2&p=50272&cat=1,42936,50298 (I like Lee Valley!)
