Pop up Treadrop
Pop up Treadrop
Postby Patchdog » Thu Jan 01, 2015 10:40 pm
Saw this pop up teardrop on facebook. Thought it would make a cool design. Anyone design anything like this before? I would think waterproofing it would be a trick.
Thanks,
PatchDog
If you need great Promo ideas just contact me.
http://extraordinarypromos.com
http://proforma.com.extraordinarypromotions
Patchdog
Re: Pop up Treadrop
Postby dales133 » Thu Jan 01, 2015 10:55 pm
Waterproofing it would be an absolute nightmare
Have a look Kimberly Kampers down here in aus, theý are alot more modern but follow a similar approach but where the outside walls lift instead of the inside witch halves the areas where it could leak.
dales133
Re: Pop up Treadrop
Postby Junkboy999 » Mon Jan 19, 2015 9:38 pm
This picture is been a around for a while. Somewhere I have about 16 photos of that one showing how it was set up. The middle section of it goes inside the hole camper when it is in the down position. I think that one will be hard to seal. Lots of water will hit the side on the top section and have no place to go but in.
Now if you have a TD that had a pop up section that covered the camper you have a better chance to keep water out.
Check out what I planing to build.
Max Headroom, A Pop-Up Benroy, planning
viewtopic.php?f=27&t=53506
Here is a great link to campers that have a pop up section in them or lifting roofs. These are all the ones that were finished buy forums members and other camper on the net. Sharon “S. Heisley” put these links together.
Teardrops & Tiny Travel Trailers with Lifting Roofs
viewtopic.php?f=5&t=50969
In the design area you will find many great and strange ideas that are just idea. Waiting for the right day and build to come along.
Junkboy999
Images: 52
Return to Member Designs
