7 x 10 Tiny Trailer
7 x 10 Tiny Trailer
Postby jwh92020 » Tue Jun 26, 2018 7:50 pm
I decided I wanted to do a full build so I started kind of small. I want it to be light weight, easy to tow and comfortable for those rainy days when outside isn't an option. I decided on a 7 x 10 platform with a 6ft interior height. Full size bed in front, 2 person dinette on passenger side rear, sink, storage and frig cabinet lower driver side rear. Upper driver side rear will be storage and a built in a/c unit. I had the frame built - 2 x 2 tubing, 40" tongue, 3500 lb axle. Cabin frame is 2 x 2s ripped from 2 x 4s. Exterior is sheathed with ThermoPly and skinned with exterior grade FRP. Roof is 24 gauge roofing metal, only 1 seam. Interior will be natural finish luan ply. No propane, all electric. Lights and device charging will be from solar. Here are some pics of the progress:
155062 155063 155065 155066
155067 155067 155068 155069
155070 155061
jwh92020
Images: 80
Re: 7 x 10 Tiny Trailer
Postby aggie79 » Thu Jun 28, 2018 8:29 am
Very nice! :applause: :thumbsup: :applause:
Do you mind a few questions? Could you provide info and/or where you purchased the FRP? Also, the same for your windows and doors.
How did you attach the FRP and the roof metal?
Thank you,
For more on our Silver Beatle teardrop:
Images: 676
Postby jwh92020 » Thu Jun 28, 2018 9:33 pm
Tom - I bought the FRP from a guy here in Oklahoma City. He has about 300 more sheets of this size and about 100 of 25 x 77 sheets. He also has about 2000 sheets of 60 x 80 Filon. He got them from a RV supply place that closed down. I got the windows from Shed Windows and More.com. 3 - 14 x 27 windows were right at $100 including shipping. I got the door from a mobile home supply store here in OKC. 30 x 72 door was $250. I used DAP Power Grab for FRP. I talked to several FRP adhesive mfgs and DAP was the only one that had done testing for outdoor use. They said it held up well during their tests. Roof is 2 48" piecesof 24 gauge metal. One sheet is flushed to one edge and the oter sheet is flushed to the other side with a 7" overlap. I ran a bead of sealant under the overlap then used Eternabond Tape on the seam. The metal is screwed to to the roof joists with metal roofing screws.
jwh92020
Images: 80
Postby aggie79 » Mon Jul 02, 2018 10:46 am
Thank you! That is great information. When I get in build mode for the second time I'm going to look around the DFW for similar materials.
Images: 676
Postby jwh92020 » Tue Jul 03, 2018 2:21 pm
A few more pics. Marker lights are mounted, tail lights mounted, 30 amp inlet mounted and the exterior trim is done.
155157
155159
155158
jwh92020
Images: 80
Postby aggie79 » Fri Jul 13, 2018 9:21 am
Love the diamond plate trim! :applause: :applause: :applause:
Images: 676
Return to Member Designs
