Thanks for the Dandan pics, Gage. I spent some time chatting with him at the IRG-4 and unfortunately, I didn't dig deeply enough into his one-of-a-kind build. He is a very interesting fellow, and has done a great job with all of that aluminum and drilled and hand-tapped fasteners, by the hundreds. Sitting a staring at my model, I realize that the horizontal stabalizer (at the rear of the craft) could be used not only as a spot to place my Coleman stove, but also provide a dead straight locatioin for the piano hinge, allowing the hatch lid to swing up to the side instead of the front. I'm sure that the lift-up cabin side door can be hinged at the top, screwed in place absolutely straight. Storage in the galley can be made accessable through the countertop, with a lift up door.
Now, a roof hatch is another consideration that could drastically conflict with the smooth lines of this craft, or should I say (teardrop). You know "has to have a galley, a bed for 2 and not be able to stand up within it". Another look at the paper model, shows me that a rounded cap up front could be hinged at the top, swing up about 90 degrees, and held shut with lever latches to provide a waterproof seal. I can crank out a 24inch diameter "nose cone" out of wood, on by lathe, which should work just fine. I do believe I will skin all 12 segments of the exterior with 1/8" plywood and cover with a still-to-be decided finish. There will be 9 circular "hoops" or ribs, that will support the 16 longitudinal members, running from front to rear. Earlier, I went out in the shop and ripped some thin 1/8th inch strips 3/4" pine and glued them together, pressed between short, matching curved members to match the hoops.
I just ran out and sanded the "sample", and am anxious to get started, for real. Sorry folks for rambling on so, but I just have to keep myself occupied and perhaps build a little rig that will serve me, as well as allowing me to share my thoughts and skills with other interested builders and campers. I'm still just trying to get folks off of the ground, out of their tents and motorcoaches and into enjoying our comfortable (and economical) way of camping.........Long live TDers & TTTs
Roly ~~ Now out to the shop and get to work, this time I will keep track of my time and materials, and take pics.
