My left knee has been bothering me.. and I am not sure what is wrong with it..
hmm I forget what day.. I did cut. split and stack about 2 cords of firewood.
hmm I think it was late Sunday we did do a mountain bike ride. I took the inefficient Enduro out. I did my downhill loop again, this time with a cycle computor. My first run was 11mph. Not fast for a downhill you say? It is steep and loose.. Originally we were crawling very slowly down it... only 3 others have tried it.. and none successfully made it. If there was a better runout at the bottom, perhaps it would be easier to let it roll.
My second run 11.6..
With the fork adjusted shorter, the bike felt much better in the tight single track.. on the climb.
My 3rd run.. 14.3.
One of my runs.. a little to much front brake.. and the back end came up.. and started trying to pass the front.
I had some runs back into the 11's.. some in the 12's. I did lengthen the fork back out, which made the bike tougher to get through the single track.. but more stable on the downhill. I did some run's in the upper 13's that actually felt slow.
I decided to try the slow twisty line down the hill again. I made it, and felt comfortable. I thought I would try one more run.. again on the twisty.. and messed up and had to put a foot down. I did not want to end on a failure... so back up again. and again I was successful 11 out of 12 runs..
