My new project need simple cad program advice
Postby Aaron Coffee » Tue Sep 08, 2020 5:05 pm
I am in the planning stages of building a replica 1920 Briggs and Stratton Buckboard Flyer.163114. Using a combination of plans, and ideas from a youtube video and original blueprints, that I found online. The blueprints were cut off and are missing the Y dimensions. I am looking for a simple, cheap cad program that I can import the blueprints to, and insert the dimensions that are there and generate the missing dimensions. I wont be using an original motorwheel rather taking cues from the you tube video.
Thanks
Aaron
Aaron Coffee
Images: 26
Re: My new project need simple cad program advice
Postby tony.latham » Tue Sep 08, 2020 7:50 pm
These?
http://horselesscarriagereplicas.com/SmithFlyerBlueprints.pdf
At least for the body, it would be fairly easy to reproduce on Sketchup. Do you need to do the whole nine yards?
Postby Aaron Coffee » Wed Sep 09, 2020 7:19 pm
Yes that would be the blueprints. Just need a couple of dimensions, then can figure out the rest from them.
Aaron Coffee
Images: 26
Postby eLink » Wed Sep 09, 2020 8:23 pm
You won't be able to import a clean CAD file from a pixelated PDF file (as far as I know).
You could try downloading a free trial version of Bluebeam. It's a PDF editing program that can help find measurements based on known dimensions.
eLink
Images: 142
Postby Aaron Coffee » Thu Sep 10, 2020 9:39 pm
Cool. Thanks, I will give that a try.
Aaron Coffee
Images: 26
Postby rjgimp » Thu Sep 10, 2020 11:43 pm
The seats are only 15.5" wide. Does one cheek go in each...?
:roll:
-Rob
rjgimp
Images: 7
Postby tony.latham » Fri Sep 11, 2020 9:27 am
rjgimp wrote:The seats are only 15.5" wide. Does one cheek go in each...?
:roll:
I caught that too. That would be a squeeze.
Aaron:
Cool project. What engine are you planning on using?
Postby Tom&Shelly » Fri Sep 11, 2020 11:06 am
:roll:
People came in different dimensions back then :lol:
Looking at the size of the engine, it may have been a subtle way to keep the payload weight under control. :thinking:
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Postby Aaron Coffee » Fri Sep 11, 2020 8:18 pm
Using a 3 hp briggs and stratton. https://youtu.be/lPDv_33CV4o. Plan is to do something similar to this engine setup, currently debating between an econo spare and a rear motorcycle wheel for the drive wheel. Plan on doing some measuring before I make seats.
Aaron Coffee
Images: 26
Postby Aaron Coffee » Mon Sep 14, 2020 7:24 pm
Thanks, I downloaded free trail of Bluebeam and within 5 minutes I was able to generate the dimensions I needed. I always know that when I have odd requests/questions that someone can guide me in the right direction here. I plan on making a mockup of the seat to see if it will fit my girlfriend, although I will breach the questions carefully, or at least I will in my mind and it will come out of my mouth otherwise. Thanks again. I will post my progress, but it will be slow as finances allow.
Aaron Coffee
Images: 26
Postby rjgimp » Mon Sep 14, 2020 9:24 pm
Aaron Coffee wrote:I plan on making a mockup of the seat to see if it will fit my girlfriend, although I will breach the questions carefully, or at least I will in my mind and it will come out of my mouth otherwise.
I have never known such a scenario to transpire in any other way.
:lol: :lol: :NC :lol: :lol: :thinking: :lol: :lol: :roll: :lol: :lol:
-Rob
rjgimp
Images: 7
Postby tony.latham » Tue Sep 15, 2020 9:42 am
Good. :thumbsup:
This will be a fun project to follow.
Postby Tom&Shelly » Tue Sep 15, 2020 10:49 am
Aaron Coffee wrote:I plan on making a mockup of the seat to see if it will fit my girlfriend, although I will breach the questions carefully, or at least I will in my mind and it will come out of my mouth otherwise. Thanks again. I will post my progress, but it will be slow as finances allow.
I agree with Rob and Tony! :thumbsup: :thumbsup: :thumbsup:
Tom&Shelly
Images: 2021
Postby Aaron Coffee » Thu Oct 22, 2020 5:08 pm
Making a little progress. Got the drivetrain mocked up. Waiting for 7 gauge plate to replace plywood, then welding.163533
163532
163531
Aaron Coffee
Images: 26
Postby rjgimp » Fri Oct 23, 2020 12:19 am
Where did you find that awesome swingarm for the drive wheel?
:lol: :thumbsup: :applause:
-Rob
rjgimp
Images: 7
