noseoil wrote:Always check the grounds first. Too many problems with lights & wiring to mention when 12 volt stuff starts looking for a ground to use. Don't ask how I know.....
bobhenry wrote:noseoil wrote:Always check the grounds first. Too many problems with lights & wiring to mention when 12 volt stuff starts looking for a ground to use. Don't ask how I know.....
I had the exact same thing on the drivers side turn signal on my HF frame. It was a quick fix for me I clamped a screwdriver into a set of jumper cables. Grounded one end to the frame and with the other I used the now grounded screwdriver and touched the barrel of the socket and it started working. The fix was a mini worm clamp around the socket with a small gage jumper wire clamped in between the clamp and the socket and then find a good ground for the other end.
ANYONE building on a HF frame I would strongly suggest you do this worm clamp trick with all the lighting and tie the grounds to a common wire and return to the tow vehicle via the 4 ,6,or 7 way plug it will save you a lot of headaches.
MichaelAnn wrote:Thank you for all of the input. I have definitely narrowed it down to a problem with the TV. Short of taking my car apart, I'm unsure of how to move forward without taking it to an auto electric place. I've checked the fuse, all good there.
