AC Hacking a Figidaire 5000 BTU
Anything electric, AC or DC
Re: AC Hacking a Figidaire 5000 BTU
Postby Socal Tom » Fri May 12, 2017 12:21 pm
2manytoyz wrote:My question on thise fans would be at what static pressure are they producing that airflow. A 5" flex duct only carries about 50 cfm at .5 in/wc if the static rating for those fans is near that then you will potentially shorten the life of the fan considerably. I do residental and commercial hvac for anliving and a 5000 btu unit (.417 ton unit) by industry norms needs about 167 cfm. Am i missing something that is radically different with using this type of unit as I am planning a similar design for my camper.
Brian
How long a run are your numbers based on? my guess is 100ft. Mine are only 5ft long, so a much higher CFM would be expected. The A/C units cost about $100 and they last for years under the short term conditions like these. If static pressure is shortening their life expectancy its not enough to show up under these conditions. According to the manufacture of mine the fan puts out between 111 and 136 cfm. I suspect that fans in these units are designed to push pretty hard, given that they have to suck across a pretty tight coil and then blow the air across the room.
Socal Tom
Images: 9
Postby 2manytoyz » Fri May 12, 2017 1:21 pm
Good to know they are holding up. I really didnt want to spend the coin on the coleman mach 8. Static and air flows are based off a 25' flex duct.
2manytoyz
Postby Shadow Catcher » Fri May 12, 2017 8:27 pm
The Atwood 4000 bilge blower is rated at 230 CFM 125 CFM in system. I have ours hooked up to a PWM to adjust speed and have it running at about half power which is enough to keep the coils from icing. My bet is that it is making up for resistance in the hosing and keeping the air flow at 125 CFM give or take.
Images: 192
Postby 2manytoyz » Sat May 13, 2017 7:25 am
Good info I was thinking I was going to have to use a freeze stat to keep it from icing. I realy like the adjustable speed idea. Being able to slow the air down to just above freezup would help with dehumidification.
Brian
2manytoyz
Postby Socal Tom » Sat May 13, 2017 12:08 pm
2manytoyz wrote:Good info I was thinking I was going to have to use a freeze stat to keep it from icing. I realy like the adjustable speed idea. Being able to slow the air down to just above freezup would help with dehumidification.
Brian
I still believe that setting up the return in a "cross flow" configuration is less likely to ice up. Unfortunately it doesn't get humid enough here in socal for me to prove it. I'm still using a cardboard plenum, so clearly water isn't an issue for me.
Socal Tom
Images: 9
Postby 2manytoyz » Fri May 19, 2017 11:50 am
Has anyone tried using either a transmission cooler or electric radiator fan? I was actually thinking about taking the condensong coil off so that i could mount it on the sidewall through a hatch wile mounting the evaporator coil under a cabinet. Should be pretty easy to design and build a shroud and new drain pan. Then add a grill for estetics a relay a transformer and a thermostat.
Brian
2manytoyz
Postby Shadow Catcher » Fri May 19, 2017 6:54 pm
Brian
Part of my thinking was that there are many times when I do not want or need AC and an integrated AC unit goes with you. I have an identical 'head unit' should the current one fail.
I do not see that there would be a real problem with a split system and actually investigated a small engine powered unit using an automotive AC compressor.
Images: 192
Postby working on it » Fri May 19, 2017 7:35 pm
2manytoyz wrote:Has anyone tried using either a transmission cooler or electric radiator fan? I was actually thinking about taking the condensong coil off so that i could mount it on the sidewall through a hatch wile mounting the evaporator coil under a cabinet. Should be pretty easy to design and build a shroud and new drain pan. Then add a grill for estetics a relay a transformer and a thermostat.
Brian
  • I tried a 10" automotive cooling fan as a cabin mounted main fan, since I am car-centric, and I wanted an automotive/industrial/farm & ranch kind of overall appearance to the trailer. There were three problems using it: 1) since I wanted it suspended from an overhead shelf, it needed a protective cage around it (the blades are quite sharp, and dangerous), 2) the amperage draw was too high (at full power, it would consume 6-7 amps from a 12vdc battery, running it down to nothing, quickly), and 3) the noise level was too much (intended for use underhood, a radiator fan was never meant to be used in a quieter locale, like a trailer cabin). I just tested with a fan I had as a spare in the race car shop (of my friend), where I was building the frame and exterior. I only entertained the thought until I connected it, and quickly disconnected it, as the roar was too much for me, inside the 4x8 cabin. I bought a 120vac 10" fan, which used a fraction of the power, was much quieter, and had a protective casing all around the blades. Much better.
  • If you used a cooling fan remotely mounted, away from the cabin, then it would work, and also have the advantage of being waterproof. But, you'd still have a power problem. A transformer would be needed for converting park power to 12vdc to run it, without depleting your on board battery.
2013 HHRv a "squareback/squaredrop" 4x8 TTT,
semi-offroad?, at barely under 2000 lbs travel weight
  • 3500 lb Dexter EZ-Lube axle, w/brakes
  • 27x8.5-14LT all-terrain tires (x 3)
  • LED lighting, triple fans. Pioneer stereo
  • A/C & heat, Optima AGM, inverter & charger(s)
  • extended-run, on-board, 2500w generator
  • Coleman dual-fuel stove & lantern, Ikea grill
  • zinc/stainless steel front racks
153929148599153928
working on it
Images: 439
Postby Shadow Catcher » Tue May 30, 2017 7:21 pm
Don't try this at home :roll:
One of the problems with the AC on the ground is the fins on the AC take beating. I purchased a set of fin straighteners at my local HVAC supplier and did my best. A guard to prevent this occurring seemed like a good idea. There are four holes on the back of the unit which had screws, very short screws (this is significant). I stuck in a wire to check for depth, (also significant). Attaching the screen to the back of the AC two of the screws went in fine the third, the sudden release of potential coolth in a
hissing stream. :cry:
Note I do have a screen which is attached to aluminum angle which is attached using 3M VHB tape to the sides of the AC
148535
Images: 192
Postby sodatrain » Thu Jan 25, 2018 7:00 pm
This is really awesome stuff. :applause: I'm working on designing a Cargo Trailer Camper (CTC) that is 7x14.
I like the window AC because it's inexpensive and can be a smaller size (5000BTU) for lower power consumption. I don't really want to cut a huge AC sized hole in the trailer so I love the hose designs. I'm thinking about trying to build something like this but mount it on the trailer tongue and maybe even just have a straight shot for the ducts into the trailer. Assuming I can mount the AC unit, protect it, etc, that seems to me like a simple way to not have to worry about duct size/length/bends hardly at all right? 5" still seems like a good idea. Right?
My 7x7x14 Tandem Axel build thread: viewtopic.php?f=42&t=69731
sodatrain
Images: 19
Postby Socal Tom » Fri Jan 26, 2018 3:21 pm
sodatrain wrote:This is really awesome stuff. :applause: I'm working on designing a Cargo Trailer Camper (CTC) that is 7x14.
If I were to do it again, I would do 4 inchs for supply and 5 inch return, but I truly believe that if you do the sidewinder design, then you can probably do 4 inches both ways.
Socal Tom
Images: 9
Return to Electrical Secrets
