Battery FAQ
Anything electric, AC or DC
Re: Battery FAQ
Postby 48Rob » Tue Jul 08, 2014 8:41 am
Thanks!
48Rob
Re: Battery FAQ
Postby OverTheTopCargoTrailer » Thu Aug 14, 2014 10:28 pm
As a update I wanna share that the 16kw - 1,250 AH Lithium batteries are fantastic.
1) they have allowed me to almost double my solar panel output to 5 x daily panel wattage
1,000 watts in flat panels is getting 5,000 watt output / storage in SF area summer time
vs. prior daily out put usage 1800 to 2,600 watts same panels with L16 Surrette 400 ah batteries.
2.) no problem running my 5,000 btu AC & also charging my batteries in full
3.) limited to no heat transfer from solar equipment as with flooded batteries.
4.) ZERO off gassing problems
5.) IMHO - Lithium is worth every single penny , works much better then ever hoped or expected.
HANDS DOWN - No comparison to flooded or AGM
:thumbsup: :thumbsup: :applause: :applause:
Re: Battery FAQ
Postby tony.latham » Thu Aug 14, 2014 11:41 pm
My only experiance with Lithium batteries are with my 12V (Dewalt drill) driver. Amazing torque, lightweight and almost full power until it's dead.
What I don't understand is how a battery change can increase your PV output?
Re: Battery FAQ
Postby jss06 » Fri Aug 15, 2014 9:19 am
Increased storage capacity?
jss06
Palladium Donating Member
Re: Battery FAQ
Postby jss06 » Fri Aug 15, 2014 9:20 am
You can only store so much before the battery gets full.
jss06
Re: Battery FAQ
Postby woytovich » Fri Aug 15, 2014 9:25 am
Are you saying that the new batteries allow the panels to push out more wattage? Is there some sort of bottleneck the the old batteries had that limits "flow" from the panels? Is that what I'm reading?
Mark - Metro New York
Toyota Land Cruisers: '66, '78 and '86
'03 Yukon XL, 2500/8.1 liter/8 lug + 18' 10k Car Trailer
M416 1/4 ton Military trailer - SOLD
5x8 Cargo/Camper - for sale soon
woytovich
Re: Battery FAQ
Postby pilot325cm » Sat Jul 15, 2017 5:20 pm
I'm tyring to buy a new battery around 85ah. Do I go with agm or regular deep cycle? Any preference on brand, optima and interstate are so expensive compared to a duracell? Any help is appreciated.
pilot325cm
Re: Battery FAQ
Postby featherliteCT1 » Sat Jul 15, 2017 6:45 pm
pilot325cm wrote:I'm tyring to buy a new battery around 85ah. Do I go with agm or regular deep cycle? Any preference on brand, optima and interstate are so expensive compared to a duracell? Any help is appreciated.
If you are new to batteries, with limited knowledge about how to charge and maintain a battery properly, but want to get something right away, you cannot go wrong with this Walmart battery for $75.
https://www.walmart.com/ip/EverStart-24 ... /180350522
This battery is not a “true” deep cycle battery and the stated amp hours is 101 at a 1 amp discharge rate (which means it probably is only about 80 amp hours at the standard 20 hour discharge rate).
If properly charged and maintained, it will probably last about two years before the capacity starts dropping off. The approximate date of manufacture is shown on the sticker. Shop around and look for a date that is only one month old, but no more than two months, otherwise you will probably get a weak battery that will never perform as it should.
If the battery needs replaced, especially when you are on the road, Walmarts are virtually everywhere.
When it is time to get a new battery, you can upgrade based upon your newfound knowledge.
featherliteCT1
Re: Battery FAQ
Postby TomD » Sun Oct 22, 2017 10:24 pm
TomD
Re: Battery FAQ
Postby gudmund » Wed Nov 18, 2020 12:15 pm
one note of caution when buying batteries at Wal-Mart nowdays = I have noticed lately that more and more of the batteries they are stocking/selling now are coming from it's either ?Korea or China? (will take a better look at them next time I go there) as time goes on, the Excide/Johnson Control stock (USA made ones) is going away as they get sold off. The company's name is something like 'Clarious' or 'Clarian' and is now making/suppling them to W/M........... :roll:
gudmund
Images: 39
Re: Battery FAQ
Postby tony.latham » Mon Nov 29, 2021 10:19 pm
Yura Liang wrote:Sodium-ion battery vs. lithium-ion battery, which do you think is better? Considering their safety, cycle life, capacity, etc.
See if https://powerstationbattery.com/blogs/blog/sodium-ion-batterie can give you any ideas.
:stompspam:
Return to Electrical Secrets
