Are both the cabin 12V electrical system and the trailer running lights grounded to the metal trailer body?
Thank you-
MtnDon wrote:Yes both are most likely grounded to the frame. Negative, or ground, is the same side of the electrical system as long as all the devices are designed to be used in a negative ground system. BUT, IMO, a properly wired trailer, cabin, vehicle, etc. will use a dedicated negative wire from each light or device, that has the other end grouped at a common negative/ground point. That point may also be connected to the frame as a ground. It is poor practice to depend on the frame as a ground conductor though.
Sparksalot wrote:I ran dedicated ground conductors for everything. I also kept the trailer running lights completely independent of the cabin electrical system.
