Solar: Trying to decide charge controller location
Anything electric, AC or DC
Re: Solar: Trying to decide charge controller location
Postby immped64 » Sun Jul 07, 2019 8:56 pm
Tony: Those numbers do look correct.
The issue comes with the required clearance above and below the unit. 6 inches in each direction for ventilation purposes.
I do have an e-mail out to Renogy. Perhaps they will say that all this clearance is not necessary or I can install this horizontally, but that would be against their pdf recommendations.
If my tongue box is a dead end for installation I have noticed online that there is a large variety of tongue boxes with depths exceeding the assumed required 20 inches.
immped64
Postby immped64 » Fri Jul 12, 2019 5:47 pm
The solar setup arrived earlier this week. Everything to this point looks as expected.
Today I had an unsuccessful shopping trip. I was looking for a Tongue box replacement but couldn't find anything locally that was near large enough. I also am running into some dead ends with the notions I have in mounting the solar panel itself. I plan to start another thread in regards to mounting the solar panel. For now I will continue with what I have run into in regards to the mounting of the charge controller.
Recapping what I have stated in a previous post: I have been concerned about my tongue box not passing the requirements for storage of the Renogy rover charge controller.
I did hear back from Renogy on my question of the charge controller placement. I was told that it does not need a %100 waterproof enclosure, yet I would want to avoid rain directly falling on it. However the lady from Renogy did recommend that I maintain a vertical mounting direction as well as the 6 inch clearance on each side. I am willing to compromise slightly on this, but intend on being as close to the requirement as possible.
The constraints that I will want to work within are as follows. I wish to have the height of box between 18 and 20 inches. Maximum depth of box would be 15 inches, preferably 14 inches. I also would really like to buy the diamond plate style of box. I was wanting to replace the flat black plastic box eventually, regardless of needing to install the charge controller. If I was to put the battery in the tongue box I could have a depth greater than 15 inches but at this point I will keep the battery in the battery box. My existing box is 36 inches at the widest point and 27 at the narrowest. This is not hard and fast, but the tapered width does look reasonable.
In today's wandering I could not find anything close to fitting my requirements. There was one box that I looked at that was 15 inches tall as well as having a depth of 15 inches.
One of the people I talked with today suggested that when I do get find my box that I would likely want to have a wall that split the container in 2. The controller would be installed on this wall. I am wondering whether someone might have a good idea of how to mount the 2 vertical edges of this wall to the tongue box?
That would be the approach I am most comfortable with. Unless there is someone who has a good reason for dissuading me from going this route this is what I plan on doing. I should be able to find a reasonably shaped box online.
immped64
Postby tony.latham » Fri Jul 12, 2019 9:20 pm
You can add a divider by attaching two pieces of aluminum angle on the walls you want to stick your divider to.
T
Postby immped64 » Sat Jul 13, 2019 8:09 am
Tony: This does sound like a good idea as it should be quite sturdy.
I am wanting to say that you would suggest that this be put together with adhesive both against the aluminum angle iron and perhaps wooden mounting plate for the charge controller. I am also thinking this might apply between aluminum angle iron and (what I will assume) aluminum sides of the tongue box.
If I am correct what type of adhesive would be recommended to hold this together? The seal would be the most critical between tongue box side walls and the aluminum angle iron. I am thinking that it may be possible that sealing would not be required between wooden charge controller mounting plate and aluminum angle iron.
If I can find a suitable tongue box this should work quite well.
The last item that I am debating is whether there might be an advantage to placing my battery in the tongue box. I am leaning against this, but perhaps it might allow for a larger tongue box if the battery was stored in the tongue box. I believe I have seen posted warnings in regards to setting up a greater likelihood of explosion, but I'm not sure I can understand this. On the other hand this wouldn't gain me a whole lot as I would still need to drill the same amount of holes into the tongue box.
Thanks for your help!
immped64
Postby tony.latham » Sat Jul 13, 2019 8:54 am
...would suggest that this be put together with adhesive both against the aluminum angle iron and perhaps wooden mounting plate...
Attache the angle to the box walls with #10 machine screws and locknuts. Attach the divider to the angle with wood screws.
Flooded lead-acid batteries vent hydrogen. That's the issue. (AGM batteries don't.) :frightened:
With my current teardrop, I have the battery in the tongue box. The only source for a spark would be from me messing with the cables but as soon as the lid is open, any hydrogen quickly rises.
:thinking:
Postby immped64 » Sat Jul 13, 2019 10:09 am
Tony:
The lock nut would be outside of the tongue box. Any idea how this should be sealed? Would JB Weld make sense here? I'm not mechanically inclined so I don't know what typically would be done. There would be a little bit of a blemish but most of it would be hidden from view by the battery box and spare tire.
I have not found my tongue box yet. (It will be a fairly easy process of elimination). If I can't stay within 14 or at the max 15 inches in depth I may opt to place the battery within the tongue box.
As far as chances of a hydrogen explosion I guess my thinking is that there wouldn't be a whole lot of extra chance for a spark to ignite within the tongue box that would be there inside of the battery box itself. It may be a little more sealed but it would still have a slight amount of air circulation to clear the hydrogen out. Typically when the sparks happen is when you are messing with the battery with what ever lid open.
immped64
Postby tony.latham » Sat Jul 13, 2019 10:13 am
Put the bolt heads outside and the lock nuts inside. Just bed each bolt head with a poly sealant like Lexel. But there shouldn't be much room for moisture to get in.
T
Postby immped64 » Sat Jul 13, 2019 11:11 am
Tony:
I will do as you suggest. That would be a cleaner looking install.
Thanks for walking me through this!
If I'm not too ashamed of my work :shock: I will post my finished result.
immped64
Return to Electrical Secrets
Users browsing this forum: Gamewell and 4 guests
