Everyone should get au fait with a DMM and ammeter...
John:
What do you use? Got a photo of your setup?
T
bdosborn wrote:Stumbled across this connector this morning, looks pretty good. I have the Perko connector that Tony linked to and its well made but the plug isn't indexed so you can touch positive to ground if you try and insert it upside down. I've never done it but it makes me nervous.
Solar Conector to SAE Adapter
tony.latham wrote:Also, maybe most people are continually topping off from tow vehicle while driving, or solar while stationary?
That's certainly the way I did it with Flash, our old teardrop that still has it's original FLA battery from 2013.
But things changed with this new build. In fact, I hesitated during a sip of coffee to sharing.
I installed a VMAX Group 24. And as we both know, VMAX batts aren't cheap. AGMs are supposed to be charged at something around 14.5V or so and automobile charging systems don't quite put that out. (And I have no idea how "smart" they are. After all, they don't even know they are dealing with two batteries at two different states of charge. And in this case two different types of batteries.)
Now, if you Google around this forum, you'll find plenty of folks that have had good success with charging AGMs off their tow vehicle. For this new build, I chose to wire the battery to the tow vehicle but included a cutoff switch so that normally the charge would only be from the solar panels ––with the controller set for AGM.
Plan A was to turn that switch on for a travel day while we were changing camps and the battery was low because of clouds, shade, or a combination.
The disconnect switch is that big red thing. (And yes, the wires are hidden these days.)
From what I have seen so far, I doubt I'll ever have to turn it on.
Did I overthink this? Ask me in eight years how that old VMAX is doing.
bdosborn wrote:I use one of these on the battery terminal for my solar charge controller wire to the battery:
Battery Fuse
#10 AWG = 30A.
Tom&Shelly wrote:
The fuses for those look a bit pricey. Of course, you don't want to be blowing them very often...
There's a fused cable too ...
tony.latham wrote:There's a fused cable too ...
I'm not seeing that in the photos, but fuses on wires are a good thing.
I'm glad you've got Bruce's attention on this thing. He's the guy that got me hooked up to the sun "back-when."
bdosborn wrote:Post a picture of the cable end on the solar panel that you'd connect to the battery and then we can figure it out...
