Here is a few things to think about .
The 5 amp start up surge is instantaneous so that does not really figure in...
The .9 amp device running at 115 volt is about a 9 amp load on battery...
With an approximate 10:1 step up in voltage, you also have to multiply load at 10x ( or 9 amps)..
Depending in amp hour rate of battery (say 400 amp hour (which is 400 amps over 20 hours )) you can run device approximately 44 hours (400/9 = 44)before battery goes below useable voltage.
All calculations are approximate as there are other losses in inverter and appliance circuits not figured in here.
Yes you can parallel battery in tear with battery in tow vehicle to charge both batteries simultaneously. But I suggest a battery isolator device to protect both batteries from possible damage due to some unforeseen incident with batteries or charging circuit...
And here is yet another site with battery information.
http://www.uuhome.de/william.darden/
Now that I have stuck my neck out on this some one will come by and correct me, and you will have right answers...
Dale
