Both AC and DC - outlets in cabin and outlets in galley to occasionally... charge a phone? use a laptop/dvd?
(we don't usually use electricity when camping)
And finally, (for now) what size battery is a good choice?
tony.latham wrote:Why not just stick with DC?
erfnie wrote:And if you don't mind me asking, how do you run a CPAP from DC? Is there an adapter to plug it in?
If that were the case, then do you still need something like the PD4045? And a shore power hookup? Cuz how does the battery recharge?
What if we were to add solar later on?
tony.latham wrote:I'm pushing towards two decades of teardropping and have no need for 120V AC. There is a small inverter in the tongue box but I can't recall when we last used it or what it powered. Why not just stick with DC?
GTS225 wrote:erfnie wrote:And if you don't mind me asking, how do you run a CPAP from DC? Is there an adapter to plug it in?
... your machine could plug into, and hook up to a power port, you'd be golden. If your CPAP ...
tony.latham wrote:In the photo of the fuse block, three's a 12v outlet to the right. That's where my CPAP plugs into.
tony.latham wrote:And for stationary charging, you could add one of these ports along with a 120v smart charger.
John61CT wrote:Can also take genset input.
Could you explain the system and components behind it (what's on the other end)?
tony.latham wrote:...That's where you'd plug in a charger inside your 'drop.
erfnie wrote:tony.latham wrote:...That's where you'd plug in a charger inside your 'drop.
You mean a charger to charge the battery?
erfnie wrote:John61CT wrote:Can also take genset input.
John, sorry, I have no idea what this is.
