saltydawg wrote:Swapping the cells is a good idea and a good way to find if one cell is weak. You could also make 2 packs and test them again and that will let you know which cell is weak.
Personally I would do the 2 pack test, you would not need to to balance them. Just hook em up and let the bms manage the charge. Then drain them and find the weak cell. You had enough of a delta finding it should be easy and not require over the top testing.
lfhoward wrote:My battery has an emergency shutoff switch right here:
