Dale M. wrote:This is "TYPICAL" of trailer wiring using the "common" 4 wire flat connector....
The ground may either connect to trailer chassis and if lights are designed to ground through mounting/chassis you are probably good. IF lights are designed to ground through mounting and mounted in wood or fiberglass you will have to hard wire a ground from connector to lights...
As a side note I always ground bond the ground connection to trailer chassis even if lights are mounted in wood or fiberglass.
Note ground from lamp to chassis (tiny black lines)...
Dale
I repeat NEVER ground trailer lights to the frame (unless you are looking forward to problems). They will work for a little while, and in some cases, where a trailer is never driven in rain and always stored inside, they may work forever. But why would you want to build in a problem? I have been a dealership mechanic for more than twenty years and grounding problems are a major part of electrical work. Each light needs its own ground wire, save yourself the headache
Brwbier
