battery charger/converter
Postby Dean_A » Tue Aug 19, 2008 7:38 pm
rhltechie wrote:oohhhhh..ok mechmagcn...i think my little bulb is starting to flicker a little! so the shore power comes in...it has your normal 120 outlet..the charger plugs into the outlet and then runs to your battery? your battery in turn running back to your fuse block which in turn goes out to your lights and etc...is this correct?
Correct. Your battery is always powering your system. The charger (plugged into the 120V shore power with an extension cord) just keeps the battery topped off.
Dean_A
Images: 55
Postby rhltechie » Tue Aug 19, 2008 7:49 pm
ok...i got it now...whew...that took long enough. :?
rhltechie
Images: 49
