Cutterpup wrote:
In my house the lights and most of the oulets are 14 gauge wire except in the kitchen, and the pool circuits which are 12 gauge.
So even if its free using very large wires bigger will cause problems. Use 12 gauge for an A/C or heater larger than 1800 watts. Voltage drop in a 12 to 15 foot trail is minor.
Dan
Cutterpup wrote:Persnickity Bruce, Your point about breaker are rated at only 80% is new to me
Dan
Cutterpup wrote:Bruce, don't get hot under the collar. Just show me a specification or a regulation fron NEC or CEC ...
<snip>
Dan
Make sure that you use only 12guage for outlets!!! All regular house wiring to outlets is 12guage!
Kerry
I ran #10 house wire under my tear, exposed, held on with clips/screws. The wire in quite stiff, the clips or a frame member are every 10 inches.... I'm not concerened..... if inside a wall,surrounded with insulation, I see no problem..
And all above are right on, it's the flexing that will kill it....
I went to buy some wire for the AC side but the Depot was closed. I ended up just going to Wally World and buying an extension cord. I'll just cut it up and use that for the wiring.
You definately want to use stranded wire in mobile applications. Mark Nemeth's 12 Volt Side of Life website offers lots of tips on 12 volt system design and contains a handy chart to determine the approprite wire gage for the anticipated circuit maximum current draw. As an added safety factor, I always upgage one wire size and then protect the circuit with a fuse rated just above the maximum anticipated current when all loads on that circuit are energized at the same time.
I read that stranded is prefered because of the ability of the wire to flex and not break. Also the stranded wire tends to make more durable DC crimp connections. I think the most secure DC connection is strand wire, crimp and also solder.
DEE BEE
Cutterpup wrote:I read that stranded is prefered because of the ability of the wire to flex and not break. Also the stranded wire tends to make more durable DC crimp connections. I think the most secure DC connection is strand wire, crimp and also solder.
DEE BEE
BUT NOT FOR 120V the solder can melt when the circuit gets hot!
Dan
JunkMan wrote: The general consensus there was to use stranded wire and not to solder it, because that makes it rigid, and therefore subject to the same problems solid wire has.
Cutterpup wrote:I went to buy some wire for the AC side but the Depot was closed. I ended up just going to Wally World and buying an extension cord. I'll just cut it up and use that for the wiring.
Cutterpup wrote:Using larger wires and circuit breakers can result in a devise over heating and burn up possibly causing a fire before the electric loads trip the breaker.
Dan
