mikeschn wrote:Q wrote:Yes, I use the same unit. Got it out of an old camper I bought for cheap. I did have to play around with the location of the thermostat so as not to alternately cook and freeze every half hour. The fan uses some power from the battery but a standard RV battery is enough for at least a couple very cold (below zero) nights.
Q
I think the main difference is you bent your exhaust at 90* while I bent the ductwork 90*.
I don't have the photo of your heater installation... do you have a copy handy? A shot from the inside and a shot from the galley?
