With 4 of the Trojans T105's you will be adding 248 pounds of battery in your trailer...... Do you really want to do that?
http://www.trojanbattery.com/pdf/datash ... Sheets.pdf
Dale
Dale M. wrote:With 4 of the Trojans T105's you will be adding 248 pounds of battery in your trailer...... Do you really want to do that?
Dale
Shadow Catcher wrote:I wrote Morningstar and asked if a solar controller could be used to regulate power into the batter from the TV and the answer is yes. The difficulty is that given a nominal 14.5 V from the alternator you might not reach full charge. I plan on trying the PWM Steca controller I have and see what happens.
Shadow Catcher wrote:I had a long discussion with one of the Lifeline/Concord battery engineers and he commented they love the Progressive Dynamics converters because they will get the battery to 100% SOC.
