Early draft of PD4045 step by step
Re: Early draft of PD4045 step by step
Postby bdosborn » Sat May 14, 2016 8:46 am
H.A. wrote:Fwiw, When describing to electrical 'lessers', its better to never mention subject of AC grounding and DC 'ground' in the same paragraph (or page for that matter)
Treat & discuss them as the entirely different things what they are.
Why is that?
Images: 777
Postby H.A. » Sat May 14, 2016 3:35 pm
Zzzz cc
H.A.
Postby bdosborn » Sat May 14, 2016 7:55 pm
H.A. wrote:Thats sort goes to the old saying, "If you have to ask, You wont understand".
Maybe, but it you truly understand how it works, you should be able to explain it clearly and simply. How about contributing to our understanding of the issues with two separate explanations that even a guy like me can understand?
Images: 777
Postby Bill n Robi » Sat May 14, 2016 9:14 pm
Great write up. Thank you. I plan on replacing the WFCO-8725 that came with my TD with the PD4045 and you helped answer a few of the questions I had.
One remaining question that maybe someone can answer. I have a charging circuit from my truck, where would that tie in?
thanks
2015 T@G Max
2015 Toyota Tacoma TRD Sport 4 Door Short Bed
Bill n Robi
Postby noseoil » Sat May 14, 2016 10:37 pm
H.A. said "They are different purposes. Negative ground of typical automotive DC circuits utilises chassis, etc. as part of the conductive path of normal operation. AC grounding is a conductive path for fault currents of AC circuits. Its not to be a current path for normal operation."
My question is this, do you ground the trailer frame to earth (& thus the other metal parts), when using 110 volts like shore power or a generator? If so, why? If not, why not?
137905
noseoil
Images: 669
Postby H.A. » Sun May 15, 2016 11:32 am
H.A.
Postby bdosborn » Sun May 15, 2016 11:33 am
H.A. wrote:Hmm.
I think I just did.
Not really, how about something like this?:
Grounding the Frame
There needs to be a path from the frame to AC ground, in case a hot wire contacts the frame. Without such a path, a person entering or leaving the trailer could become the path to ground and be electrocuted. Run a green wire from the ground bus to the frame.
There needs to be a current return path from the frame to your AC power source. This ensures that the breaker opens if the hot wire ever comes in contact with the frame. Without it, the breaker wont open and the frame is energized at 120V. A person touching the frame would become the return current path and be electrocuted. Run a #12 green insulated wire from the ground bus to the frame. Strip the paint off the frame where you connect the wire so there's a good connection. Be careful not to connect the neutral and the ground together inside the converter. This can cause the frame to be energized if the campground receptacle has the hot and neutral reversed. Keep the neutral and grounds separate in all your wiring for the same reason. Its a good idea to carry a receptacle tester with you and check the campground receptacles to make sure the hot and neutral aren't switched before you plug in.
Grounding DC
This is controversial. Because all the DC goes through the converter, which is grounded via the AC ground wire, some say there is no need to ground the various appliances and fixtures to the frame. Others say that it is a must, but I’m not clear on why.
Bonding the battery to the frame is not as clear as the AC approach. Trailer manufacturers will use the trailer frame for the DC current return path to save money on wiring. A connection from the trailer battery to the frame is not needed when the trailer is connected to the tow vehicle as all the power for lights and brakes comes though the the trailer connector. A bond from the battery to the frame also provides the same function as it does with the AC system; it provides a return path for current to blow a fuse if a 12V positive wire touches the frame. Most people omit the connection to the frame if they're not using the frame as a current return path to the trailer battery as the risk of electrocution death at 12V is much less than at 120V. However, it's a good idea to provide the connection as it's an easy way to provide another level of safety in your electrical system. The green wire from the battery negative terminal to the frame should be the same size as the positive wire from the converter to the battery. And don't worry, stray AC currents won't charge your battery through the frame connection. The AC ground wire only carries current during a fault if you've installed your wiring correctly.
P.S. There's a general perception among specifiers that tandem breakers are of lesser quality than single breakers, FWIW.
Images: 777
Postby bdosborn » Sun May 15, 2016 11:45 am
Bill n Robi wrote:One remaining question that maybe someone can answer. I have a charging circuit from my truck, where would that tie in?
Just use one of the fuses in the converter. Make sure you use a big wire from the truck to the trailer. A #10 or larger. Voltage drop gets to be a problem over the distance from the truck alternator to the trailer battery. I would use a 30A fuse with a #10 wire. My truck had a #18 wire in the factory wiring harness and it was useless due to VD.
Images: 777
Postby H.A. » Sun May 15, 2016 12:39 pm
Zzzzz
H.A.
Postby springdew » Tue May 17, 2016 1:15 pm
Wow, so much discussion. Thanks everybody! There will be a lot to refine for my next draft.
I've been away building. Soon as I get my roof panels screwed on, I'll be ready to rough in the electrical. So exciting!
For everything there is in this world, there is someone who likes it.
Planning and build journal for Yiayia's Waggon: At Home on the Road
Spring Dew Foulger
springdew
Images: 9
Postby TigerHawk » Tue May 17, 2016 8:19 pm
On figure 3 - Zac's Diagram - there appears to be an additional bus bar at the far right that includes an A/C hot to converter, and an A/C hot from the 2nd breaker (for the converter). My pd4045 has the A/C hot wire crossing from the DC side to the AC side. I was under the impression that this would just be directly connected to the 2nd breaker. The image leads me to believe there is another buss bar in there but perhaps I am seeing it incorrectly. Can you provide clarification?
Thank you
TigerHawk
Postby H.A. » Wed May 18, 2016 1:47 pm
Zzzzzz
H.A.
Postby Bill n Robi » Wed May 18, 2016 5:18 pm
Can someone let me know what the physical depth really is? I think the spec is including the bezel and I what to make sure I have enough room behind to mount it.
Thanks
2015 T@G Max
Bill n Robi
Postby lrrowe » Wed May 18, 2016 5:31 pm
I would say about 1/8 in from memory. But you need to be concerned with having enough room at the back for the wiring, both AC and DC, to exit and turn if needed. Plus if you plan on installing the wires after the unit is installed, without much room to maneuver, that will be a difficult task.
Bob
lrrowe
Images: 439
Postby TigerHawk » Fri May 20, 2016 11:50 am
springdew wrote:[*]If no battery, run a wire from the negative bus bar you set up in Step 7 to ( … where? I haven't found this answer yet.)
This is the question I really need answered. I was not planning to run/use a battery at this time with my PD4045. So for the d/c lights/fan, I will bring all negative to a bus bar, and then where? If I had a battery, I would connect to the Negative post. What about if one is not running a battery?
The electrical may be the most difficult part of the camper yet because of my lack of knowledge of the area. I could always re-cut wood, sand out imperfections and such, but I certainly don't want a camper that's going to be my "electric bed." :?
TigerHawk
