My Electric Saga Part II--Newbies, Pay Attention
Postby cracker39 » Mon Jan 16, 2006 11:52 am
madjack wrote:...you will aslo need some resin core solder and preferably some heat shrink...soldering wire together is easy...twist the wires together in a straight line...put the heat source on one side of the work and apply the solder to the other side...when the solder flows thru the work you are done...just dont move the piece until solder has hardened...
MJ, do you use any flux? I usually put a little flux on the wires first, heat it to melt it in, then apply the solder. Or, does resin core solder negate the need for flux?
Dale
cracker39
Images: 233
Postby madjack » Mon Jan 16, 2006 12:01 pm
Dale, if you get resin core electrical solder there is no need for the flux...makes it cleaner and easier
Postby Chuck Craven » Mon Jan 16, 2006 7:43 pm
Hay Ira take white electrical tape and put some tape at each end of the neutral wires. Then a real electrician will know the red wire is neutral. :roll:
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
